Go to Post Give a group of engineers the choice of three options, and they'll pick choice number seven. - Taylor [more]
Unread 27-01-2007, 20:16
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Welding Aluminum MIG or TIG?
Our team is thinking about welding aluminum. Our problem is we can't TIG weld because we don't have the machine nor the experience. Now we have a Aluminum MIG welder, but the aluminum tends to warp due to the heat. How do we MIG weld accurately with minimal warping?
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 27-01-2007, 20:44
Dick Linn's Avatar
no team (Synergy)
Re: Welding Aluminum MIG or TIG?
Go to http://www.hobartwelders.com/mboard/ and search around. Aluminum welding isn't exactly easy, but it can be done. There are some really good weldors there. Search around before you ask a redundant question.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 29-01-2007, 17:33
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
1. you need aluminum feed wire
2. you need pure argon gas (not CO2)
3. If you're welding a chassis, and you weld the top side first and then the bottom, the entire chassis will curve upwards. Hence, first tack weld the entire thing together and then weld top-bottom-top-bottom, etc, flipping the frame over every weld. And make sure you do the symetrical side so you dont get corner warping.
If it's your first time welding aluminum, practice a lot on scrap metal first. Make sure everything is grounded cleanly and securely. Sand the oxidation off the ground contact and the places that will be welded.
Other than that, MIG and TIG welding can be almost equally as effective. In my experience TIG makes a better looking weld, but in FIRST I doubt you care.
Unread 29-01-2007, 23:23
jmcglash jmcglash is offline
jmcglash is an unknown quantity at this point
Starting with the filler 4043 is easy to weld with compared to 5056 but 5056 feeds better in a mig setup.
Argon gas is a must
CLEAN metal is a must. NO sand paper (aluminum oxide is evil). Scrub
with a stainless steel wire brush.
AlumiClean - Aluminum Cleaner & Brightener will strip all oxides better than a wire brush.
8020 and the like is Anodized Aluminum and the anodized layer must be
removed first. Dollar store oven cleaner is lye (Sodium Hydroxide) is a
spray can and will remove the anodized layer in about a minute.
4 part each weld, looking at the clock face 1-3 6-9 3-6 9-12 and skip
around the piece. this will keep the heat down. Even so clan the part
well.
The advice to practice on some scrap is very good advice.
Good luck and have fun with it.
Jim
Daru Daru is offline
Daru has a spectacular aura aboutDaru has a spectacular aura about
We had an expert welder come in to weld our chassis for us. (who just so happened to be my girlfriend's brother) He used a TIG welder (preference? don't know), and the welds look very nice and clean.
He didn't clean any of it, he told me that you only need to clean the oxidation off if you aren't a good welder It's contrary to what I have read (everywhere), but eh... he's the welder Something about not heating it too long so you blow a hole in it...
Now to what I personally believe. I have welded only steel with either a MIG or a TIG welder. I am by no means an expert welder, but I can manage to make two peices of metal stick to eachother.
I find the TIG welder easier to manage, it's small and light, but you need a good pair of steady and coordinated hands. I also think TIG is brighter, so it's easier to see what you're doing.
I get neater looking welds with a MIG welder, and you don't need to be as steady or coordinated. It also helps to use two hands on the one thing, so you can keep it a little steadier.
--- im rambling...
I think if you're set up to do aluminum on a MIG welder, go for it. If you've never welded before, get a few hours in on steel before even trying aluminum. MIG is easier to get the hang of, and it will definantly suit your purpose.
Good luck!
Dave
Unread 30-01-2007, 00:53
razor95kds's Avatar
razor95kds razor95kds is offline
razor95kds has a spectacular aura aboutrazor95kds has a spectacular aura aboutrazor95kds has a spectacular aura about
We weld aluminum all the time with a Mig welder and it works perfectly. You defintely need pure argon gas and your welder should move pretty quickly while he is welding. we crank the voltage and the feed rate to the maximum settings when welding .125 in thick bars. Aluminum isn't extremely difficult to weld on, just remember to move quickly and practice on the scraps you can.
Unread 30-01-2007, 01:24
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Can you please share make and model of the welder, spoolgun or standard feed, and post a picture of one of your welds? Thanks.
Unread 30-01-2007, 02:02
run the trap!!!
Team Role: Human Player
Or... You could do the opposite, which would be easier. I'm no pro, but I have more control when the feed is low.
If its your first time welding a frame I might suggest that you be liberal with the welds. Although they may not have the beauty of a thin bead a thick weld will have a better chance of getting maximum penetration. Don't be afraid to glob it on.
(but remember to alternate between welds to avoid warpage)
-Philip J. Fry
Unread 30-01-2007, 03:17
Daniel367's Avatar
Daniel367 Daniel367 is offline
Dan
AKA: Daniel Rahamim
FRC #0008 (Paly Robotics)
Daniel367 is on a distinguished road
Send a message via AIM to Daniel367
my best suggestion for tips on welding is going to the miller website and looking at their tips pages here
as for prefence i dont have one because i have only used TIG and stick welding.
Unread 30-01-2007, 13:05
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
My high school shop teacher (who was an accomplished steel welder), compared MIG welding aluminum to "melting two sticks of butter together". He never was able to get the hang of it, even when we brought in new, better equipment.
Jeff Waegelin
Unread 31-01-2007, 00:02
WRGibbens WRGibbens is offline
Instructor Materials Fabrication
FRC #1583 (Rambotics)
WRGibbens will become famous soon enough
You might want to lacate your local Miller or lincoln suppler when i set up my shop we split it 40-60, 40% tig's and 60% migs and I have learned over the years that a good percentage of my students do much better with the tig process rather than mig when it comes to alloy welds, Spool guns are a lot harder to manage than a tig turch if you can braze tig is the way to go..
most of the supplers will rent the equipment at a fraction of the cost and will answer most all your qustions. If your looking to buy a machine I would look at a Miller Maxstar tig price range is around $800.00 complate it is portable and will run on 110 or 208 volts and will weld up to 1/4" aluminum with no problems we run a helium process on most of our aluminum projects including the robot frame how ever Argon works well also.. When welding just mak sure your parts are clean you have a good fit-up and clamp your parts take your time you will produce a much better weld.
Good luck
Unread 31-01-2007, 01:17
Andy A. Andy A. is offline
Getting old
FRC #0095
I strongly urge you to ask around the community in order to find an experienced welder who would be willing to do critical welds for you and also share as much experience as he/she can. Most welders enjoy what they do, and I've never had any trouble getting them to donate some time or getting them to talk.
I've learned a bit about welding from written guides, a lot from watching and talking with an experienced welder and the most from just sneaking in an hour here and there in the welding shop messing around on scrap. The more time you spend looking at puddles, listing to the arc and getting a feel for heat the more natural welding becomes. There really is no replacement for making mistakes when it comes to learning a new skill.
So, ask around at a welding supply store for any welders that might be interested in helping out your team. You might offer to pay for con$umables, and he might offer to supply equipment. You might get those pretty TIG welds yet!
-Andy
Unread 31-01-2007, 10:00
cbpetrovic's Avatar
cbpetrovic cbpetrovic is offline
AKA: Mr. P
FRC #0166 (Chop Shop)
cbpetrovic is a jewel in the roughcbpetrovic is a jewel in the roughcbpetrovic is a jewel in the rough
Send a message via AIM to cbpetrovic
TIG, for sure. Look around in your area for a welding supply company and see if they offer classes. Maine Oxy in New England has some good classes.
This is truly an art, but not a black art. The key is knowing how when to stop before getting into serious trouble (melting the ends of your stock) and how to fix mistakes.
Then...
Practice.
Practice.
Practice...
Unread 01-02-2007, 00:11
Rick's Avatar
Rick Rick is offline
Ready to STRIKE!
AKA: Rick Blight
FRC #0078 (AIR STRIKE)
Rick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond repute
To see some nice TIG welding, check out Episode 3 of American Robot.
Like Aquidneck Island Robotics on Facebook!
Unread 01-02-2007, 11:22
JustinMilne's Avatar
JustinMilne JustinMilne is offline
FRC #1901 (Ram Rod)
JustinMilne is an unknown quantity at this point
you need tunksten wire thats all i know
ARC Welding Aluminum Simon Strauss Technical Discussion 12 20-09-2006 19:45
Stick Welding Aluminum sanddrag Technical Discussion 2 02-02-2006 13:17
MIG Welding Aluminum sanddrag Technical Discussion 11 15-09-2005 13:50
Questions on MIG Welders Jay H 237 Technical Discussion 21 12-05-2005 21:47
SCRRF - TIG Welder Redhead Jokes Southern California Regional Robotics Forum 4 10-01-2003 13:11
