Go to Post I think it's great the way people involved in FIRST always try so hard not to argue. It's a good sign that all the talk of Gracious Professionalism is working. - BaldwinNYRookie [more]
Unread 29-01-2007, 17:18
Brigander's Avatar
Brigander Brigander is offline
Website Wizard
AKA: Andrew Roberge
FRC #1723 (F.B.I)
Brigander is an unknown quantity at this point
Problem with Modified Code
Whenever I try to upload modified code to our robot controller, it refuses the modified code. but when i try the default code it works fine. can anyone help me figure out a solution to this?
Only those who do not try are doomed to fail.
Unread 29-01-2007, 22:16
Re: Problem with Modified Code
Can you be more specific? "Refuses the modified code" is a nice turn of phrase, but it doesn't say much about what is happening.
Unread 29-01-2007, 22:17
Shinigami2057 Shinigami2057 is offline
Slackware Is Your New God (Mentor)
AKA: Harry Bock
FRC #1350 (Rambots)
Shinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really nice
Define "refuses." If the code loads all the way, but does not run (code error), then make sure you are calling Getdata/Putdata and not getting stuck in an infinite loop. If the user processor cannot communicate with the master processor (by means of Getdata/Putdata) then the code will not run at all.
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
Unread 30-01-2007, 00:44
Goldeye Goldeye is offline
AKA: Josh Hecht
FRC #0694 (Stuypulse)
Goldeye has a spectacular aura aboutGoldeye has a spectacular aura aboutGoldeye has a spectacular aura about
Send a message via AIM to Goldeye
I find the same problem happens if you try to upload for the wrong processor.
Make sure if you are working with the full size controller, you're setup to work with the new (18F8722 iirc) processor.
Team 694
2005 Championship - Galileo Semifinalist
2005 New York - Regional Chairmans Award
2005 New York - Semifinalist (Thanks 1257,1340)
Unread 30-01-2007, 08:15
Brigander's Avatar
Website Wizard
AKA: Andrew Roberge
FRC #1723 (F.B.I)
The code loads but does not run... so you are saying that it might be a Getdata error? I will try this.
Unread 30-01-2007, 08:20
Electrical Engineer
Rookie Year: 1995
It comes down to this... What did you change?
Mike Betts
As easy as 355/113...
Unread 30-01-2007, 08:24
65_Xero_Huskie's Avatar
65_Xero_Huskie 65_Xero_Huskie is offline
One T
AKA: Mat
65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute
If you post part of the code u changed, im sure the "Pro"grammers on here can help you with your problems. Turst me, ive seen it done before.
Min-Max to the Max!
Unread 30-01-2007, 08:25
Brigander's Avatar
Website Wizard
AKA: Andrew Roberge
FRC #1723 (F.B.I)
I only changed the inputs for the PWM outputs... made it so that you use two joysticks to drive with
analog inputs to pwm outputs
pwm01 = p1_y;
pwm02 = p1_y;
pwm03 = p2_y;
pwm04 = p2_y;
pwm05 = p1_x;
pwm06 = p1_x;
pwm07 = p2_x;
pwm08 = p2 _x;
pwm09 = p1_wheel;
pwm10 = p2_wheel;
pwm11 = p3_wheel;
pwm12 = p4_wheel;
Unread 30-01-2007, 08:28
One T
AKA: Mat
I remembered when we switched our program to run a 360 controller, all of our PWMs were out of order so we had to imput the correct PWMs into the code, maybe you dont have the correct pwms set up for what you need to drive.
Min-Max to the Max!
Unread 30-01-2007, 08:45
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
I think there's a typo:
pwm08 = p2 _x;
it's
pwm08 = p2_x;
But I think he rewrote the whole code into the post and accidently typed space there.
Ah, ok. What did you plug in to what PWM output?
Unread 30-01-2007, 08:54
Brigander's Avatar
Website Wizard
AKA: Andrew Roberge
FRC #1723 (F.B.I)
only tested the first 4 pwm ports for the motors nothing was hooked into 5-12 at the time
more description... when i load non-default code all i get in the terminal window is "IFI>"
Unread 30-01-2007, 21:18
Electrical Engineer
Rookie Year: 1995
pwm01 = p1_y;
pwm02 = p1_y;
pwm03 = p2_y;
pwm04 = p2_y;
pwm05 = p1_x;
pwm06 = p1_x;
pwm07 = p2_x;
pwm08 = p2 _x;
pwm09 = p1_wheel;
pwm10 = p2_wheel;
pwm11 = p3_wheel;
pwm12 = p4_wheel;
Andrew,
You changed something else. Try running windiff to compare default and modified source code files.
Mike
Mike Betts
Unread 31-01-2007, 08:20
Brigander's Avatar
Website Wizard
AKA: Andrew Roberge
FRC #1723 (F.B.I)
what is windiff? where can I find it?
Unread 31-01-2007, 09:02
Electrical Engineer
Rookie Year: 1995
A google search yields many references including this.
Mike Betts
Unread 31-01-2007, 13:25
Brigander's Avatar
Website Wizard
AKA: Andrew Roberge
FRC #1723 (F.B.I)
ok i think the issue is resolved. thanks for all the advice.
Modified default code gives "code violation" scottmso Programming 8 10-02-2006 23:17
problem loading code with ifi loader psych0gambit Programming 7 25-02-2005 20:43
problem with the default code MarkVH Programming 7 28-01-2005 00:04
Problem with FRC Default code AsimC Programming 2 11-01-2004 19:22
One final fairly massive problem with the code... authgeek1218 Programming 5 19-02-2003 16:51
