Go to Post 12 is a dozen, 13 a bakers dozen...47 will be a delphi. - Kimmeh [more]
Unread 11-01-2007, 19:26
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Question:Power Distribution Block.
Can somebody explain the Power Distribution block that we have to use on the robot this year. I do not fully comprehend its purpose or its functions. If someone could help I would greatly appreciate it.
Thanks,
Pavan.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 11-01-2007, 19:30
AdamHeard's Avatar
Lead Mentor
Re: Question:Power Distribution Block.
This diagram provides some incite.
Unread 12-01-2007, 12:11
Please download the Tips and Guidlines document for a better explanation of the this required part.
Unread 24-01-2007, 17:33
udzap's Avatar
udzap udzap is offline
FRC #1290
udzap is an unknown quantity at this point
Thats easy the Power Distribution Block (PDB) can give 4 things power with only 1 wire coming from the battery. Same with "-" side. The PDB is very useful for getting power to multiple objects but they only give one so use it wisely. I hope this helps.
Unread 25-01-2007, 07:50
Don't forget you can use both sides of the block.
Unread 25-01-2007, 10:34
flearocksmybass flearocksmybass is offline
AKA: Ben
FRC #0555
Team Role: Electrical
flearocksmybass is an unknown quantity at this point
Send a message via AIM to flearocksmybass
do we really have to use that gigantic hunk of wasted space?
Unread 25-01-2007, 11:37
You have to use it, but it doesn't have to be either gigantic or wasted. It's modular. If you don't need all the connections, don't install all the sections.
Unread 26-01-2007, 07:09
MercBenzAMG's Avatar
MercBenzAMG MercBenzAMG is offline
Electrical Lead
AKA: Bobby
FRC #0151 (Tough Techs)
MercBenzAMG is just really niceMercBenzAMG is just really niceMercBenzAMG is just really niceMercBenzAMG is just really nice
so, i can cut down to one red, and one black section? why not just let me not use it, so i dont have extra space and ugliness on my god plate!!
Bobby - Senior
Electrical Lead,Coordinator, Animation, Driver / Human Player, Mechanical, Design, Chairman's, Media, Public Relations, (just about everything except software)
And i still have time to eat food :-)
www.toughtechs.org
RIT - 2011
Unread 26-01-2007, 09:01
I wouldn't do that. The distro blocks are useful for returning all the high current motors to the negative lead of the battery. You need at least 2 of the red blocks to distribute positive to the Maxi block and smaller fuse panel. Remember, only one #6 wire per terminal. One in and two outs requires two blocks and the jumper plug.
Unread 26-01-2007, 14:08
AKA: Dr. Brooks
no team (WRRF)
The power distribution block is required according to the rules, and you need to pay careful attention to the details when you assemble it, both to satisfy inspection requirements and to minimze voltage drop on the jumper that might also be aptly described as the "fuse." This is a heavy item, so it pays to leave off sections you don't need, but be careful to follow all of the wiring rules and guidelines.
Route your 6 gauge power line (from the breaker) into the block and your 6 gauge power line to the 40 amp maxi fuse block in the same section of the block (opposite sides) so that this high current connection does not go through the jumper. Pay close attention to assembly instructions, and allowed wire counts for the connections, found in the "Battery Power Terminal Strip" document found at http://www.usfirst.org/community/frc...nt.aspx?id=452. I am willing to bet that many teams will guess at this and run into trouble during their technical inspections.
The most critical current handling is for your drive motors, especially if you are using four CIMs on the drive. Your #10 ground lines coming back from your drive motors can be attached in pairs to the ground terminal block, and if you use four motors for your drive you should use two adjacent block sections, feeding the 6 gauge ground line to the other side of one of them.
If I had a spare jumper, aka the "fuse," I would hook it up to TIG welder set for 120 amps or so and see if I could blow it, or at least melt the plastic cover off of it...
Eugene
Unread 29-01-2007, 16:17
D.Stephenson's Avatar
D.Stephenson D.Stephenson is offline
AKA: Denise
FRC #0871 (West Islip Robotechs)
D.Stephenson is on a distinguished road
Send a message via AIM to D.Stephenson
quick question about the block, the yellow center part, can we cut that down to fit because we are not using the full red and black parts we are only using about 1 section of each
Thanks
Team 871-Since 2002
Unread 30-01-2007, 07:40
Thanks
Denise,
Again you need to use the distro block for the high current (40 amp) returns for your four position Maxi block and all feeds to the smaller fuse panels. As to cutting the jumper, there is currently no rule for this part. I suggest you ask the Q&A. Ideally, you should be able to cut this to fit you design, but it would need to be insulated in some fashion as the cut would expose metal that is connected to the battery.
Unread 30-01-2007, 08:57
If you're only using one section of the distribution block, the yellow jumper piece serves no purpose. It is intended to connect adjacent sections.
Unread 30-01-2007, 10:01
roboticsguy1988's Avatar
roboticsguy1988 roboticsguy1988 is offline
Larry Johnston
AKA: Larry Boy
FRC #1501 (Team THRUST)
roboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud of
Send a message via ICQ to roboticsguy1988 Send a message via AIM to roboticsguy1988 Send a message via MSN to roboticsguy1988 Send a message via Yahoo to roboticsguy1988
I would agree that there could be better methods of wiring this. However rules are rules and you can still make a great looking electrical board which doesn't weigh much. We calculated ours to weigh about 11.187 pounds.
My thought on the power distribution block was along the lines of you can do the same thing with the maxi breaker block. Notice it has 3 holes on the incoming. Use one for the main read wire coming from the 120A main breaker. then use the other 2 to go to the smaller panels for the 20A and 30A breakers. However this is NOT legal according to this years rules.
I still say the IFI breaker panel was the best way to go, I am really curious as to why FIRST doesn't approve of it.
Larry Johnston, Team THRUST, Team #1501, Team THRUST webpage
2005 IRI - Imagery and Design Award
2005 - 2006 BMR - Professional Grade Award
2006 BMR - Delphi Driving Tomorrow's Technology Award
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~ RogerR
~Da team that uses all tha rivets, Team #1501~
The FIRST Software Repository ~ Chief Admin
openFIRST ~ Project Supporter (Former editor)
DMOZ.org - FIRST - US Teams Section ~ Chief Editor
Unread 30-01-2007, 22:15
AKA: Denise
Denise,
Thanks!!!
Team 871-Since 2002
Power distribution Block? Pontchartrain Electrical 3 27-01-2006 07:30
Power Distribution Block - Green Light Mike General Forum 8 12-01-2006 21:59
Stinger Fuse Block and Power Distribution Block Don Wright Electrical 2 30-03-2004 10:45
Power Distribution Block DukesElectrical General Forum 0 09-02-2004 23:48
