Go to Post so instead of saying why, we said why not? - Alpha Beta [more]
Unread 30-01-2007, 09:19
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
Re: Gear tooth sensors - Forward or backward?
You are correct. Last year's gear tooth sensor (ATS651LSH) had two different pulse widths depending upon direction of rotation ( 45 us and 90 us - typical ). For this year's gear tooth sensor (ATS642LSH) the pulse width will vary based upon the speed of the rotation of the gear and the shape of the gear teeth as seen by the sensor. see the complete data sheet at www.allegromicro.com
FRC 623 2003,2004,2005,2006,2007,2008, 2009, 2010, 2011
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 226 and 369 2008, 2009, 2010, 2011
FTC 3806 2010
Help with the Kit Gear Tooth sensors Keo-san Programming 9 20-02-2007 08:07
where can we buy hall effect sensors or gear tooth sensors amirjpl Electrical 3 13-02-2006 11:02
Gear Tooth Sensors et1337 Electrical 7 28-01-2006 22:48
Source for Additional Gear Tooth Sensors Madison Kit & Additional Hardware 3 18-01-2006 16:57
Accelerometer vs Gear Tooth Sensors zdeswarte Electrical 4 22-01-2005 15:35
