Go to Post Because the new control system weights as much as a fully-loaded M1 Abrams Tank. - artdutra04 [more]
Unread 10-01-2007, 19:44
DustinB_3 DustinB_3 is offline
FRC #0935 (Railerobotics)
DustinB_3 is an unknown quantity at this point
Potentiometer with ADC
I've searched chiefdelphi and didn't come up with anything. But, how would I go about coding a potentiometer with the ADC. I am quite new to using both the potentiometer and the encoder. Help is much appreciated.
Unread 10-01-2007, 19:56
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: Potentiometer with ADC
It's pretty simple. Wire the potentiometer to a PWM cable (I forget how to do this since I didn't do it), and plug it into one of the appropriate RC inputs. I'm fairly sure that the white cable of the PWM cable is the signal line, while the red and black ones are positive and ground. Once it is set up, it should simply be the potentiometer with the PWM cable hanging off it. There is no need for additional wires or power.
Once you've done that, you can access whatever values it is reading with the function Get_Analog_Value(int whichInput).
For example, our potentiometer in the 2006 robot, we did:
curPotentReading = Get_Analog_Value(rc_ana_in03)
If I remember correctly, the returned value will be between 0 and 1024, since it is a 10-bit ADC.
Unread 10-01-2007, 22:33
Thanks for the reply but I am not sure that that would work because you have to comment out Set_Number_of_Analog_Channels(SIXTEEN_ANALOG); in order to get the adc to work correctly
Unread 10-01-2007, 22:38
Bongle's Avatar
I just checked our 2006 code which had a flawlessly working potentiometer, and we still had that line of code.
Here's our whole User_Init. Aside from the commented-out line for the shooter switch, I think it is unmodified from the given code.
void User_Initialization (void)
  Set_Number_of_Analog_Channels(SIXTEEN_ANALOG);    /* DO NOT CHANGE! */
//	shooter_switch=1;
/* FIRST: Set up the I/O pins you want to use as digital INPUTS. */
  digital_io_01 = digital_io_02 = digital_io_03 = digital_io_04 = INPUT;
  digital_io_05 = digital_io_06 = digital_io_07 = digital_io_08 = INPUT;
  digital_io_09 = digital_io_10 = digital_io_11 = digital_io_12 = INPUT;
  digital_io_13 = digital_io_14 = digital_io_15 = digital_io_16 = INPUT;
  digital_io_18 = INPUT;  /* Used for pneumatic pressure switch. */
     Note: digital_io_01 = digital_io_02 = ... digital_io_04 = INPUT;
           is the same as the following:
           digital_io_01 = INPUT;
           digital_io_02 = INPUT;
/* SECOND: Set up the I/O pins you want to use as digital OUTPUTS. */
  digital_io_17 = OUTPUT;    /* Example - Not used in Default Code. */
/* THIRD: Initialize the values on the digital outputs. */
  rc_dig_out17 = 0;
/* FOURTH: Set your initial PWM values.  Neutral is 127. */
  pwm01 = pwm02 = pwm03 = pwm04 = pwm05 = pwm06 = pwm07 = pwm08 = 127;
  pwm09 = pwm10 = pwm11 = pwm12 = pwm13 = pwm14 = pwm15 = pwm16 = 127;
/* FIFTH: Set your PWM output types for PWM OUTPUTS 13-16.
  /*   Choose from these parameters for PWM 13-16 respectively:               */
  /*     IFI_PWM  - Standard IFI PWM output generated with Generate_Pwms(...) */
  /*     USER_CCP - User can use PWM pin as digital I/O or CCP pin.           */
  Setup_PWM_Output_Type(IFI_PWM,IFI_PWM,IFI_PWM,IFI_PWM);
     Example: The following would generate a 40KHz PWM with a 50% duty cycle on the CCP2 pin:
         CCP2CON = 0x3C;
         PR2 = 0xF9;
         CCPR2L = 0x7F;
         T2CON = 0;
         T2CONbits.TMR2ON = 1;
         Setup_PWM_Output_Type(USER_CCP,IFI_PWM,IFI_PWM,IFI_PWM);
  /* Add any other initialization code here. */
  Init_Serial_Port_One();
  Init_Serial_Port_Two();
#ifdef TERMINAL_SERIAL_PORT_1
  stdout_serial_port = SERIAL_PORT_ONE;
#endif
#ifdef TERMINAL_SERIAL_PORT_2
  stdout_serial_port = SERIAL_PORT_TWO;
#endif
  Putdata(&txdata);            /* DO NOT CHANGE! */
//  ***  IFI Code Starts Here***
//  Serial_Driver_Initialize();
//  printf("IFI 2006 User Processor Initialized ...\r");  /* Optional - Print initialization message. */
  User_Proc_Is_Ready();         /* DO NOT CHANGE! - last line of User_Initialization */
Unread 11-01-2007, 00:04
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
DustinB_3 you must be using Kevin's code. If you are you just follow the instructions to integrate his code into yours, or use his complete project.
Then to get the value you call Get_ADC_Result(unsigned char port#).
The following code would get the value from analog input 1.
int position = Get_ADC_Result(1);
Hope this helps.
Eric Haskins KC9JVH
Unread 11-01-2007, 08:21
Thanks for the help. That was exactly what I was looking for.
Unread 30-01-2007, 12:41
stevethetinker stevethetinker is offline
FRC #1288 (RAVEN)
stevethetinker is an unknown quantity at this point
Does anyone know what resistance potentiometer to use?
Unread 30-01-2007, 12:56
Anything from 2k to 100k ought to work. Higher resistances will be slightly more susceptible to noise. We've used 10k with good results.
Unread 30-01-2007, 13:26
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
This year we're using 5k ohm pots with great success.
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 03-02-2007, 17:10
Shinigami2057 Shinigami2057 is offline
Slackware Is Your New God (Mentor)
AKA: Harry Bock
FRC #1350 (Rambots)
Shinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really nice
I have a dumb question - I Just hooked up a 100K pot to analog input 01, but Get_Analog_Value(rc_ana_in01) is only returning values from 0-9, and it definitely is not linear. This is the (very simple) code we're using just to test:
printf("%u\n", Get_Analog_Value(rc_ana_in01));
Am I missing something important here? Is there something wrong with the pot? (It's wired correctly)
Thanks
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
Unread 04-02-2007, 08:05
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Thanks
The problem is that Get_Analog_Value returns a 10-bit value, rather than an 8-bit value. In general, we discarded the lowest 2 bits of the potentiometer value as "noise" and just used the top 8 bits via the following code:
 int Get_Robot_Pot(void) {
    unsigned char robot_pot_8bits;
    // analog inputs on the robot are returned as 10 bit values, the line below
    // drops off the bottom two bits to give a one-byte value for the elevation
    robot_pot_8bits = (unsigned char) (Get_Analog_Value( rc_ana_in01 ) >> 2);
    printf("Pot Value: %3d\r\n", (int) robot_pot_8bits);
    return ((int) robot_pot_8bits);
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 04-02-2007, 13:39
AKA: Harry Bock
FRC #1350 (Rambots)
How is that a problem when analog inputs return an unsigned int (16-bits on the PIC18, more than enough for the 10-bit ADC conversion)? I'm assuming %d is expecting an int, so it should be fine. Even if the compiler was lopping of the 2 MSbs of the result, it should still return a value from 0-255.
Thanks for the help, though. We're going to try some new linear taper 10k/50k pots tomorrow. We really weren't sure exactly what kind of pots the old ones were, only that they were 100k ohm.
Unread 04-02-2007, 13:54
Define "correctly".
Use a voltmeter to look at the signal (white) wire. It should vary from 0 volts to 5 volts as you turn the pot. If it only gets up to a few millivolts, it's possible that you have the ground and wiper connections swapped.
Unread 04-02-2007, 14:19
AKA: Harry Bock
FRC #1350 (Rambots)
I'll definitely check that, thank you. We currently have the pot wired so that the signal wire is in the center, which I assumed to be the wiper based on a previous topic here. Do all pots use the center connection for the wiper?
Unread 04-02-2007, 15:04
That's true of all of the generic single-turn pots I'm familiar with. However, the five- and ten-turn pots are different, with the wiper at one end and a little offset from the other two connections. The linear "slide" pots don't seem to have a consistent pattern.
Motor with a built in Potentiometer..? Kaushal.K Motors 5 09-01-2007 08:31
With gyro need to access ADC for poteniometer mrozek Programming 0 21-02-2005 13:39
error with adc.h incognito_NICK Programming 2 05-02-2005 23:27
Potentiometer with BS2 sanddrag Programming 7 13-05-2004 19:21
ADC problems with C library and new code Larry Barello Programming 1 09-01-2004 22:31
