Go to Post CD makes FIRST an infinitely better place. - lemiant [more]
Unread 28-01-2007, 01:26
Japper's Avatar
Japper Japper is offline
FRC #3692 (RocknRobots)
Japper has a spectacular aura aboutJapper has a spectacular aura about
Servo Connection questions
I am new to using servos and don't know a heck of a lot about them...
I would like to use one for operating my manipulator jaws. The jaw has a relatively light spring loaded mechanism which I am guessing might work well for a servo.
Now for the questions:
Do the servos connect directly to the PWM outputs?
Where can I find some information on how to program the servos and some application information that might suggest some mechanical coupling ideas to use with these?
Thank you
Last edited by Japper : 28-01-2007 at 01:28. Reason: forgot to set email notification
Unread 28-01-2007, 01:40
Daniel367's Avatar
Daniel367 Daniel367 is offline
Dan
AKA: Daniel Rahamim
FRC #0008 (Paly Robotics)
Daniel367 is on a distinguished road
Send a message via AIM to Daniel367
Re: Servo Connection questions
yes the servos connect directly to the PWM out puts on the robot controller.
as to the programing of them i don't know but i suggest checking the programing forums for info. (unless you already did that in which case ignore what i last said)
-Dan
Unread 28-01-2007, 12:59
Joohoo's Avatar
Joohoo Joohoo is offline
FRC #0340 (G.R.R.)
Joohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really nice
Send a message via AIM to Joohoo Send a message via Yahoo to Joohoo
yes you can plug the servos directly to the rc but you have to make sure the backup battery is hooked up and charged.
in regards to the programming of it think of it this way the servo takes it's entire range of motion and divides it by 256 where 0 is at one extreme and the other extreme being 255.
Unread 28-01-2007, 17:09
Japper,
The servo is a motor driven mechanical device that does not have a 360 degree rotation on the output shaft. The mechanical and electrical charachteristics are available on the manufacturers website and require some interpretative reading to understand. The max rotation is given in degrees but since the parts and the mechanical stop vary from part to part, you need to expect that your servo may have slightly less or greater travel. Watch also the max torque spec. The data sheet will also give you some insight into the operation with specific PWM values. The servo will receive it's power via the PWM cable from the RC and the backup battery, so be sure to check the operation at 7.2 volts or lower when designing your application.
Unread 30-01-2007, 13:05
Japper's Avatar
Thanks for the info...
I do not have the part with me and would like to look up the specifics of the two servos that were included in the kit. Does anyone have that info or a link to the specific info to the servos that are included in the 2007 kit?
Thanks
Unread 30-01-2007, 13:31
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Thanks
This is all I could fine:
http://www.hitecrcd.com/homepage/product_fs.htm
Unread 31-01-2007, 00:55
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Thanks
The specific servo in the Kit of Parts is the Hitec HS-322HD. This is the only servo permitted, but you may use more than the two that come in the kit, as specified by rule R45.
For manufacturer specs:
Overview - http://www.hitecrcd.com/Servos/hs322hd.htm
Manual - http://www.hitecrcd.com/Servos/Servomanual.pdf
Spec Sheet - http://www.hitecrcd.com/Servos/spec_sheets/HS322HD.pdf
Best regards!
--ken
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 03-02-2007, 15:15
teddybear teddybear is offline
FRC #0234
teddybear is an unknown quantity at this point
Exclamation Re: Servo Connection questions
What exactly is a servo connection sir? I have just joined team 234, and haven't really learned that much anyway.
Unread 03-02-2007, 17:27
Teddy,
The servo is a device that is used in RC cars and airplanes. It is a positional device that can be controlled via PWM signals to turn to a certain angle. It is not capable of turning a full 360 degrees but can control other items like the pan and tilt of the camera which do not require a full 360 degrees of motion.
Japper,
I am afraid they might not be powerful enough for your application but you should try and see if you could give them some mechanical advantage.
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
Spike Connection Gal Longin Control System 4 12-01-2005 13:59
Spike Connection Gal Longin Electrical 4 12-01-2005 13:59
Championship Connection Jordan Rumor Mill 3 13-11-2002 22:41
Network Connection archiver 2001 5 23-06-2002 23:42
