Go to Post It was the stupidest rule, but a rule is a rule, and everyone has to follow them. - RyanN [more]
Unread 29-01-2007, 08:00
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Paperless Process
We took our first crack at a paperless process, (CAD to Mill without drawings), and I was wondering how many other teams do this regularly?
vid of process... http://www.youtube.com/watch?v=jrkeA6DFAK0
For those that do, what are you using to create the tool paths?
We've been using Inventor for the CAD and then translating to stp so that tool paths can be created in Key Creator (school's CAD), but the loss in associativity in the transfer creates a pinch point in the work flow waiting for tool paths. Anybody got alternatives out there that work with Inventor?
Unread 29-01-2007, 14:02
Re: Paperless Process
Several members of our team (and a few other local teams) took a machine shop class at the local community college (El Camino College). Now that we've passed the class, we have full access to the school's machine shop.
They use Mastercam, which imports directly from Inventor. We also tried Inventor to STP to Mastercam, which was a mess.
So far, we've made 2 parts paperless, and redrew a third.
Unread 29-01-2007, 15:21
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
With the exception of parts made on our lathe and drilling simple holes with a drill press, all of our processes are completely paperless. Parts made on the lathe are not paperless only because its CNC capabilities leave a lot to be desired -- though the potential to use it as such is there.
Nearly all parts are designed in Solidworks, though sometimes we'll use Microsoft Visio for simple, two-dimensional parts.
For parts made on the mill, I use MasterCAM V.9 to create all of the toolpaths. We have a license of MasterCAM X as well, but I prefer V.9. The mill has onboard software to execute the code.
For our plasma cutter, we use SheetCAM to automatically generate toolpaths. It's a very fast process, as SheetCAM is very good at determining kerf compensation on its own and generates the toolpaths in less than a second. The plasma cutter is driven by software called Mach3. It's pretty easy to use, though the interface is a bit cludgy.
Finally, our laser cutter behaves as a printer, so we can print parts to it directly from within Microsoft Visio.
We're able to make parts reasonably quickly and they're accurate. It's enormously helpful and we've been able to eliminate a lot of work remaking parts that aren't up to snuff because of human error. I don't know if I could go back to doing all of this any other way.
--Madison--
...down at the Ozdust!
Unread 29-01-2007, 16:01
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
You can use Ace DXF converter for 2D machining to make G code from a DXF file. It is free. I like SheetCAM too. It is like $150 or something like that.
Unread 29-01-2007, 19:05
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
The newest Key Creator can import directly from Inventor, but a nice alternative is Surfcam...
Unread 29-01-2007, 19:38
AdamHeard's Avatar
Lead Mentor
My team is in the same class..
Just to make it easier on the machinest that go there, I give them inventor files, step files and a paper drawing so there is no confusion. They say they have had the most success with inventor files though.
Unread 30-01-2007, 10:07
Daniel_H's Avatar
Daniel_H Daniel_H is offline
FRC #1156 (Under Control)
Daniel_H is just really niceDaniel_H is just really niceDaniel_H is just really niceDaniel_H is just really nice
unfortunately our machine shop is very limited, so we make tons of .idw files
[<o>] gogogo [<o>]
http://undercontrol1156.com/
Unread 30-01-2007, 11:44
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Yeah, only problem is it's like $15,000
I like GibbsCAM, but probably because it's the only thing I've used.
2001-2004: Team 100
2006-Present: Team 254
Unread 30-01-2007, 13:34
Rafi Ahmed's Avatar
Rafi Ahmed Rafi Ahmed is offline
Mentor & Alumni
FRC #2522 (Royal Robotics)
Rafi Ahmed has a spectacular aura aboutRafi Ahmed has a spectacular aura about
Our team mostly has drawing in Inventor and CAD so we can just use the CAD files and use GibbsCAM to machine them. We used inventor to gibbs one time to machine our frame but most of our CAMing is done from CAD files.
Team 2522 | Mentor
Formerly of Team 22 and Team 4
Unread 01-02-2007, 18:41
kramarczyk's Avatar
I've since discovered that the school is a couple revs behind in Key Creator and plans to update this summer which wil help for next season. Thanks to everybody for thier feedback. MasterCAM looks like the ultimate solution though... anybody tried for a donation from them before?
Unread 01-02-2007, 19:15
FlashCut seems decent too for 2D stuff.
Unread 01-02-2007, 22:56
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
We're still using paper for everything
I wish we had a CNC mill (anyone got an extra?)
Unread 04-02-2007, 19:49
MitchellDonovan MitchellDonovan is offline
FRC #0234
MitchellDonovan is an unknown quantity at this point
Nope, our printer runs all the time.
Unread 04-02-2007, 20:24
GMAdan's Avatar
GMAdan GMAdan is offline
Team member turned mentor
AKA: Daniel A. Cobar
FRC #1881 (GAMMA Elite)
GMAdan has a spectacular aura aboutGMAdan has a spectacular aura about
Send a message via AIM to GMAdan
At our school we use edge cam its like master cam.
Heck Freezes After The Thaw: Paperless Monopoly? Joe Matt Chit-Chat 11 30-07-2006 21:04
Inspection process ttedrow Regional Competitions 14 08-03-2004 20:12
Process Destroying (C++) Raven_Writer Programming 9 19-01-2004 20:47
Planning Process Ravi U Chairman's Award 1 07-01-2004 18:12
Application Process Nick Seidl College Teams 2 11-09-2003 17:23
