Go to Post My mom's cousin heard from her friend who heard from her brother who heard from his barber who heard from his son that his teacher told him that his father's brother's sister's former roommate heard from Frank himself. - notmattlythgoe [more]
Unread 30-01-2007, 13:35
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Resizing Camera View
Originally Posted by stevethetinker View Post
I've tried using the VW command while the camera is streaming data (T packets from Track Color), and often it seems to shut the camera down.
What are the rules for sending a command to the camera? Call Camera_Idle first? Wait for an ACK?
I tried adding a state to Kevin's code between STATE_TWO and STATE_THREE, and the first call to Write_Camera_Module_Register times out. (no ACK returned). That's all I did - add a no-action state. (I want to put a Poll Mode command there but that didn't work so I took out the command and its wait for ack, thus adding a no-action state).
Yes, you need to call Camera_Idle( ) before calling Virtual_Window( ), waiting for ACKs after each.
If you want to call Virtual_Window( ) from the initialization function, this is a fragment from some code I'm working on:
case STATE_SIXTEEN:
// initialize the Noise Filter value
Noise_Filter(Camera_Config_Data.NF);
// next state
state = STATE_SEVENTEEN;
// wait for an ACK before transitioning to the next state
wait_for_ack =1;
break;
case STATE_SEVENTEEN:
// set window size
Virtual_Window(60, 100, 100, 239);
// next state
state = STATE_EIGHTEEN;
wait_for_ack =1;
break;
case STATE_EIGHTEEN:
// send the TC or Track Color command
Track_Color(Camera_Config_Data.R_Min,
Camera_Config_Data.R_Max,
Camera_Config_Data.G_Min,
Camera_Config_Data.G_Max,
Camera_Config_Data.B_Min,
Camera_Config_Data.B_Max);
// next state
state = STATE_NINETEEN;
wait_for_ack =1;
break;
case STATE_NINETEEN:
// signal that we're done
return_value =1;
break;
-Kevin
Kevin Watson
http://kevin.org
Camera Help (New to Camera Programming) Idaman323 Programming 6 14-01-2006 03:56
Camera View Size pyrr101 Programming 0 10-01-2006 22:42
Image resizing tips? jpsaul7usa Chit-Chat 5 04-03-2005 00:52
Resizing pictures.. Brandon Martus CD Forum Support 4 26-02-2004 15:22
Resizing Assemblies in Inventor Jeff Waegelin Inventor 7 25-02-2003 13:43
