Go to Post "The devil" isn't in the details... The devil is having a loud house party with lots of other devils and demons in the details. And laughing, and laughing... - pfreivald [more]
Unread 30-01-2007, 13:44
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Banebot 56mm gearbox - double D related
Once again, forgive me I haven't had a chance to tear into the thing yet, but I thought of a potential solution many teams may be able to implement and perhaps make several of to supply to other teams in trouble.
Would it be possible to machine the planet carrier and output shaft from one solid piece of steel? Start with round bar the diameter of the carrier plate, Turn it all the way down. I know it's a long ways to go but CNC can help with that. Drill new planet pin holes. Cut a keyway. Is there any reason it must be two pieces? If we did this, what material should it be made from to not yield the material due to torsional shear where small diameter meets large? I would like this to eliminate any possibility for failue in the 2 motor 12:1 scenario.
small banebot motor with 64:1 gearbox burkey_turkey Motors 16 29-01-2007 01:48
opening up the BaneBot gearbox to install the CIM motor jskene Motors 9 22-01-2007 11:12
Banebot Gearbox chris31 Technical Discussion 45 15-01-2007 17:56
Attempting to Cut BaneBot 56mm Shaft edthegeek Motors 6 15-01-2007 08:51
56mm BaneBot Gearbox 15tooth sprockets. Where to buy more? VEN Technical Discussion 4 11-01-2007 14:45
