Go to Post Looks great! Love that Indiana engineering!! - Mr.D [more]
Unread 30-01-2007, 13:49
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Banebot 56mm gearbox - double D related
The output shaft is actually 1/2" (0.500") at the "outside" end, and 12mm (0.472") where it passes thru the bearings. So, you could not assemble the gearbox with your plan, unless you changed the whole bearing mounting design.
The obvious solution to the problem is to spline the shaft and plate, but then you get into interchangeability and manufacturing issues.
small banebot motor with 64:1 gearbox burkey_turkey Motors 16 29-01-2007 01:48
opening up the BaneBot gearbox to install the CIM motor jskene Motors 9 22-01-2007 11:12
Banebot Gearbox chris31 Technical Discussion 45 15-01-2007 17:56
Attempting to Cut BaneBot 56mm Shaft edthegeek Motors 6 15-01-2007 08:51
56mm BaneBot Gearbox 15tooth sprockets. Where to buy more? VEN Technical Discussion 4 11-01-2007 14:45
