Go to Post If you are old then our lead mentor is ancient. Oh wait, he is. Oh wait, that makes me ancienter. - JaneYoung [more]
Unread 30-01-2007, 14:45
LieAfterLie's Avatar
LieAfterLie LieAfterLie is offline
FRC #2028
LieAfterLie is an unknown quantity at this point
Re: Evaluation Board Gyro
How exactly would you hook up the normal gyro and how impossible is it?
SEMPER UBI SUB UBI
Unread 30-01-2007, 15:14
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Originally Posted by LieAfterLie View Post
How exactly would you use the normal gyro and how impossible is it?
You can use the gyro with code created by Kevin Watson, available at http://kevin.org/frc. Readme files included in his code instruct you on what needs to be done to get the gyro working, and it is pretty much as easy as following those directions to be able to use it (though it will probably take a good 30 minutes or hour to get the gyro working if you've never done it before).
As for what you can use the gyro for, that's left up to your team's imagination.
Unread 30-01-2007, 15:24
FRC #2028
And is there any difference between the programming for the normal gyro and the EB gyro?
SEMPER UBI SUB UBI
Unread 30-01-2007, 16:02
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
programming wise if you use the AnalogDevices gyro it will be the same. I believe Kevin Watson's code is set to use both the 150 deg/sec and the 300 deg/sec gyro, if that is what you are using. If using EasyC I think you need to scale the output by a certain factor to get the correct output. It depends on which model you are using.
Unread 07-02-2007, 18:27
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
From our experience, if using Kevin's code, you'll probably also want to narrow the gyro deadband if you're using a 300 deg/sec gyro (else it won't see small rotations).
Unread 08-02-2007, 08:52
haroony341's Avatar
haroony341 haroony341 is offline
FRC #0341 (Wissahickon HS & NMTCC) FRC#2234 (The Episcopal Academy)
haroony341 is an unknown quantity at this point
Send a message via AIM to haroony341
we used the gyro ordered from FIRST and wired just the 3 twist holes to pwms, but we get the same random reading if the gyro is attached or not. im assuming this is a soldering issue. but what else could it be? do you need to wire the Temp (R)?
Drexel University Class of 2009 -- Computer Engineering
Team 341 Miss Daisy // Wissahickon High School @ NMTCC
http://www.team341.com
Team 2234 // The Episcopal Academy http://www.ea1785.org/robotics
Unread 08-02-2007, 11:31
kaszeta's Avatar
You don't need to wire them up to the Temp.
It's probably a soldering issue.
Unread 11-02-2007, 13:08
haroony341's Avatar
i hooked up the gyro to an oscilloscope and it worked fine there. and the soldering looks ok too. what exactly would we be looking for when the gyro is connected to the RC with WPI?
Lights in Joystick board or control board rcubes85 Control System 15 26-02-2005 23:40
Gyro magical hands Programming 2 14-01-2005 20:57
Perf Board = BS2-IC Carrier Board? indieFan Electrical 2 16-09-2004 08:28
Gyro archiver 2001 2 23-06-2002 23:11
