Go to Post edit: laptop. yeah as a programmer to not put this in I should be taken out the back and "decompiled". - Stuart [more]
Unread 30-01-2007, 17:06
Nate Laverdure's Avatar
FRC #2363
Re: Manipulator(Arm) Help
Some of my unused arm ideas from earlier on in build season:
Both are simplified versions of a double-jointed idea, fit within 38" at start and within 72" when fully extended, and assume a 13" high chassis. I hope they give you a few ideas!
Unread 30-01-2007, 17:27
in between teams
AKA: Luke Van Oort
I would look into drawer slides. You could easily add a stage of forklift style elevation with some drawer slides and angle or box aluminum to mount them on, sort of like the 229/217 arm from '05. (A video of this arm design can be found here if how I am describing it is confusing)
Team 1219: 2009 - Mentor
Most Impressive Manipulator santosh Technical Discussion 28 08-06-2005 22:44
Manipulator designs Max Lobovsky Technical Discussion 10 27-01-2005 07:43
I Need Help With An Arm Team ICE #1611 General Forum 4 20-01-2005 14:37
anyone use an arm to help balance archiver 2001 8 24-06-2002 02:46
