Go to Post The fact that although many of us disagree on specifics of how FIRST should conduct events, design a game, and facilitate as much fairness between teams as possible, in the end we still greatly enjoy each other's passion for FIRST and provide genuine respect for each other - Andy Baker [more]
Unread 30-01-2007, 18:05
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Beginning of Match - Charged tank
Tuba,
The problem with venturi vacuum systems is you need airflow to the develop the vacuum. Without the robot running, keeping a charged tank while waiting for the match to start is going to be difficult.
Yes I agree, but once you have a vacuum you can engage the tube and lock it in. It is possible to do this manually during the field setup before the robot is enabled. We have tried it out and it works! If you establish a good seal with the tube, the vacuum will maintain for quite a long time. You just have to figure out a way to prevent atomspheric pressure from leaking back in at all possible openings HINT HINT!
Using pre-charged accumulators Peter Matteson Pneumatics 8 14-02-2006 10:42
beginning of a match Jess1513 Rules/Strategy 2 10-02-2005 22:05
Single Tetras at Beginning of match? Deltafrog Rules/Strategy 6 09-01-2005 12:48
Charged 7.2 battery Daniel Brim Electrical 2 01-02-2004 10:46
Under or Over? To tank or Not to tank that tis the question! archiver 2001 2 23-06-2002 22:53
