Go to Post You can never have enough FIRST! :D - Koko Ed [more]
Unread 30-01-2007, 18:42
RaMoore's Avatar
RaMoore RaMoore is offline
AKA: Rachel Moore
FRC #3005 (RoboChargers)
RaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud of
Re: Banebot 56mm gearbox - double D related
Originally Posted by Joe Johnson View Post
Some questions:
Why do it 3 times?
Did you "temper" the part after the final time you quenched it?
Will you do your test again only with the non-hardened carrier for a baseline?
Thanks for the data.
Joe J.
We did it three times to guarantee that we got hardening all the way to the core of the material. To harden the material further we would have to use higher temperatures and cool it faster and we felt this was unnecessary. Before hardening we were able to easily shave pieces of steel off the edges (using a pocket knife) and after the third quenching we could no longer shave large pieces of material off.
We didn’t temper the material following the third quenching because hardening the material to the point we would need to temper it is beyond our capabilities.
We will repeat the test with one of our unhardened carriers and post results soon.
Rachel Moore
REV Robotics | www.revrobotics.com
small banebot motor with 64:1 gearbox burkey_turkey Motors 16 29-01-2007 01:48
opening up the BaneBot gearbox to install the CIM motor jskene Motors 9 22-01-2007 11:12
Banebot Gearbox chris31 Technical Discussion 45 15-01-2007 17:56
Attempting to Cut BaneBot 56mm Shaft edthegeek Motors 6 15-01-2007 08:51
56mm BaneBot Gearbox 15tooth sprockets. Where to buy more? VEN Technical Discussion 4 11-01-2007 14:45
