Go to Post I'm frustrated by the world's reluctance to bend over backwards for FIRST. - Madison [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 30-01-2007, 09:53
SPARKY1688's Avatar
SPARKY1688 SPARKY1688 is offline
AKA: Marko Rajacic
FRC #1688 (StickShift)
SPARKY1688 will become famous soon enoughSPARKY1688 will become famous soon enough
Exclamation 2005 Robot Controller?
Here we go,
So yesterday we were test driving the robot and I made the electronics a little too close to the out side edge so the radio, tether, and prog connections were facing the outside left side of the robot so when you connected the cable it would stick out like a 1/4 inch, so we were driving the robot and the cable hit a little ground electrical box and snapped the the radio input of the robot controller. Now I wanted to know since this happened late last night can we use the 2005 controller for the camera and can we use it during competion time. I checked the rules and cant find it. In conclusion I going to call if today and see if they can fix it!
Thanks,
Marko
Unread 30-01-2007, 11:49
Re: 2005 Robot Controller?
The 2005 and 2007 Robot Controllers have different processors. You can't just swap one for the other without choosing the appropriate library files and recompiling the code.
<R27> Motors, pumps, and, Robot Controllers from previous robots can not be used in addition to those provided in the 2007 Kit Of Parts. They may be used as direct one-to-one SPARE PARTS for those provided if the provided part fails or is damaged. They can only be used if they are identical to the part being replaced.
I believe a 2006 (or an upgraded 2005) Robot Controller should be considered identical to a 2007 Robot Controller, but I haven't seen anything in the Q&A to confirm that.
Unread 30-01-2007, 12:43
SPARKY1688's Avatar
AKA: Marko Rajacic
Yeah I reprogrammed the 2005 controller and it interfaces properly with all 2007 operator and radios, everything works. Will i be able to use the 2007 camera on this system temporarilly until i get the new one fixed?
Unread 30-01-2007, 13:05
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
You can use the 2007 camera on the 2005 RC. I'm not sure I saw any difference except for the power switch. But its hardware is identical.
Amperage Robotics Team 1225
Site under-going revamp. :/
Unread 30-01-2007, 14:17
dtengineering's Avatar
AKA: Jason Brett
We busted up our 2005 controller at the GTR doing something similar... the tether cable got yanked while we were driving under tether control and pulled the tether connector off the circuit board.
With help from an IFI rep we were able to open the RC case and solder the connector back into place. It has worked fine since.
Hopefully your damage is repairable, if not by your team, then by IFI.
Jason
Unread 30-01-2007, 14:21
AdamHeard's Avatar
Lead Mentor
For testing, you can make the 2005 work while the new one is being fixed.
You can't compete with it though.
Unread 30-01-2007, 16:28
DARKAGE's Avatar
DARKAGE DARKAGE is offline
AKA: Vic
FRC #0441 (Devil Dogs)
DARKAGE is an unknown quantity at this point
Send a message via Yahoo to DARKAGE
Could we use up to two controlls or only 2??? because i need to know because are robot might need four controlls.
Unread 30-01-2007, 16:31
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
A word of caution: thumbscrews are your enemy.
Never ever ever do the thumbscrews on your Tether port ever. You'll run out of cable and break something on the OI or the RC end.
While doing the thumbscrews to attach the Competition Port to your OI is a good idea while competing, be sure to undo them before walking away with your controls! I've had a few close calls...
Unread 30-01-2007, 18:50
Only one competition controller (RC), which is what is being talked about here. For speed controllers (which are different), I believe it's one per motor on most motors.
Looking for 2005 or 2006 Robot Controller Daru Control System 8 27-12-2006 01:21
Problem with the 2005 controller Guy_E Programming 10 18-12-2006 01:38
Wanted: 2005 Robot Controller BSMFIRST Control System 0 01-03-2006 11:27
porting camera code to 2005 bot controller dwc309 Programming 6 28-02-2006 19:16
robot controller 2005 2004 CharlieWilken Programming 5 20-02-2006 09:43
