Go to Post "No wheels, no problem, we can fix it in programming." - clean399 [more]
Unread 30-01-2007, 12:29
Agent Gruer Agent Gruer is offline
A newbie
FRC #1977
Team Role: Student
Agent Gruer is an unknown quantity at this point
Manipulator(Arm) Help
My team is facing some problems with our arm. We are trying to stay 4 feet tall and our arm is going to be 59.96 inches long. It is going to be resting at a 45 degree angle going to the floor. Now here is our problem, it is too long for our base and too short to reach the top. Can anyone help me? I want to keep it at 4 feet taller, no higher. Thank you!
Unread 30-01-2007, 12:50
yodameister yodameister is offline
The Mad Chemist
FRC #2791
yodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant future
Re: Manipulator(Arm) Help
How about trying a double jointed arm. This way you can fold up the arm and still stay within your size limits and reach the top row. There are other methods that you may look into. This is just one idea.
Name:	double jointed arm.JPG
Unread 30-01-2007, 13:02
anotherforrokid's Avatar
anotherforrokid anotherforrokid is offline
FRC #1230 (Lionics)
anotherforrokid is an unknown quantity at this point
i agree u should do a double jointed
we are going for the 12 inches and we are using the double jointed arm too much like the pic...
also try to set the arm less than the degree mesure u first tried...
PaUlO.WooDruFf
Unread 30-01-2007, 13:13
Liz Smith's Avatar
Liz Smith Liz Smith is offline
believes in robots
AKA: Pika1579
FRC #3940
Liz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond repute
Send a message via AIM to Liz Smith
Agreed. There are other options (such as a telescoping, or scissor-type) which are also possible, but I think that a double jointed arm is the easiest to do. I've had experience working with all three of those types of designs, so if you have any additional questions about them, just ask!
Alumna of 555 Mentor of 3940
Volunteering since 2004: Say hi to me at events!
Applications Engineer
AndyMark, Inc.
Unread 30-01-2007, 14:10
dtengineering's Avatar
AKA: Jason Brett
Remember that you are not REQUIRED to reach the top row. Although this is a desirable trait, and there are many ways to achieve it, you do not NEED to be able to do this.
It may turn out that being able to score on the two lower racks, repeatedly and reliably... because you got the arm finished a week earlier and had time to tune and test... is more valuable than stressing over reaching the top row.
Of course this is a question only your team can answer, and I encourage you to push the limits of what your resources (mental, physical and financial) allow you to build... but a robot that gets 6 tubes in a row on the bottom rack will always beat a robot that only gets four on the top.
Jason
P.S. That said, we are going for all three levels... but I do wonder if we are making the best decision.
Unread 30-01-2007, 17:06
Nate Laverdure's Avatar
FRC #2363
Some of my unused arm ideas from earlier on in build season:
Both are simplified versions of a double-jointed idea, fit within 38" at start and within 72" when fully extended, and assume a 13" high chassis. I hope they give you a few ideas!
Unread 30-01-2007, 17:27
in between teams
AKA: Luke Van Oort
I would look into drawer slides. You could easily add a stage of forklift style elevation with some drawer slides and angle or box aluminum to mount them on, sort of like the 229/217 arm from '05. (A video of this arm design can be found here if how I am describing it is confusing)
Team 1219: 2009 - Mentor
Unread 30-01-2007, 18:06
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
Originally Posted by Paul
Ah! The manipulator arm! The manipulator arm! (MST300K- The Movie anyone?). I've checked out some vex designs and watched a show on them on Discovery, they look supercool. But yeah, double-jointed is my concensus as well. That would work best. But watch the weight on the end of it mind you!
Or possibly a spring loaded hinge?
Unread 30-01-2007, 19:12
A newbie
FRC #1977
Team Role: Student
Here is some of th picture of the idea showing where our problem is, maybe this will give a better example of my team's trouble. (See Below,.zip file) THANKS!!
Unread 30-01-2007, 19:18
FRC #2363
I couldn't extract your zip archive. No files to extract?
EDIT: thanks, I forgot I had 7-Zip on my computer. Unzipped fine.
Unread 30-01-2007, 19:31
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
try using a program called 7-zip. it works for me using that
Unread 30-01-2007, 19:49
Liz Smith's Avatar
believes in robots
AKA: Pika1579
FRC #3940
Stuffit Expander worked for me on my macbook as well
AndyMark, Inc.
Unread 30-01-2007, 19:56
fluffy's Avatar
fluffy fluffy is offline
What color was that wire again?
AKA: David
FRC #3663 (CPR)
fluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to behold
Send a message via MSN to fluffy
winRAR also works nicely
but to help answer your problem: you could make your arm a little shorter and have a manipulator that grabs the tubes from the bottom, so it doesnt have to reach all the way to the top, but enough that the top of the tube clears the rack
Unread 30-01-2007, 20:01
Liz Smith's Avatar
believes in robots
AKA: Pika1579
FRC #3940
From the drawing, im not sure exactly how the heights are going to work out. You say the max. height your robot can reach is 107.67'', which is when your robots arm is completely vertical. To me, that seems fine, as David said, if you pick the tube up from the bottom, you may not have a problem reaching the top spider leg.
From the picture though, the arm is at an angle, making the max. height significantly lower. Is that the problem you were referencing? If so, we can discuss further improvements on the design.
AndyMark, Inc.
Unread 30-01-2007, 22:23
65_Xero_Huskie's Avatar
65_Xero_Huskie 65_Xero_Huskie is offline
One T
AKA: Mat
65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute
Have you tried a 4 bar linkage?
Min-Max to the Max!
Most Impressive Manipulator santosh Technical Discussion 28 08-06-2005 22:44
Manipulator designs Max Lobovsky Technical Discussion 10 27-01-2005 07:43
I Need Help With An Arm Team ICE #1611 General Forum 4 20-01-2005 14:37
anyone use an arm to help balance archiver 2001 8 24-06-2002 02:46
