Go to Post There's lots of other "stuff" that make a team work well in the FIRST environment, beyond designing and building a robot. - KathieK [more]
Unread 21-01-2007, 18:30
pbrules15 pbrules15 is offline
AKA: Ronny
pbrules15 is an unknown quantity at this point
Problem with easy c pro and mechanum wheels
We are trying to write some code in easy c pro to control our mechanum wheels. I have seen the code from team 40 and it is does not do what we want it to do. Each mechanum wheel has its own drive motor and we are controlling them with 2 joysticks in the tank format. We would like to have our x axis of our joysticks control the movement left to right with the mechanum wheels (move both joysticks left, straif left. Move both joysticks right, straif right).
Here is the problem, I have written the code to control it in tank setup, and I have written code to control the straif setup. Independently, the two work fine, but I cannot figure out how to join them together. When combining the two, the robot spazzes out all the motors at once. I can still control the robot but it is not smooth at all.
My code is attached. Please help.
Thank you
Unread 22-01-2007, 07:45
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Problem with easy c pro and mechanum wheels
So you want the robot to drive forward like a tank.
Two sticks forward.
You want it to rotate like a tank
One stick forward and one back.
You want to strafe side to side with one stick or both?
Unread 22-01-2007, 19:29
AKA: Ronny
That is correct. Although, today I have found my problem, and now it works perfect. Well, almost. All the wheels do not move at exactly the same speed and the robot drifts a little bit, but I think the problem could be our joysticks.
But I do have another question. I have heard that in Easy C Pro you can type in the code manually instead of using the flow chart. But I cannot figure out how! I checked the help file. It says that you can, but I cannot figure out how. How?
Unread 22-01-2007, 20:26
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Does your mecanum drive have any feedback installed or is it completely open loop? If it's open loop, the problem is probably not with your joysticks -- but with the inherent inequalities in the mechanical properties of the motors and gearboxes controlling each wheel.
--Madison--
...down at the Ozdust!
Unread 22-01-2007, 22:23
Kingofl337's Avatar
AKA: Adam
You click on the Project Tab and Add a source file by right clicking on "Source Files". You can also right click on a function you have created and right click and convert it to "C" code.
Also, we had some trouble with the encoders coming loose at the end of the season and it caused issues
with the robot drifting while driving strait. So we went open loop and it was better then malfunctioning encoders
but not a whole lot.
Unread 30-01-2007, 17:55
AKA: Ronny
Thanks for the help!
So, for example, we cannot edit the operator or atonomous function because we did not create it ourselves?
Also, we are havin a big ole problem. We cannot figure how to make the camera track in easy c pro. I cannot find an example of the camera tracking in easy c pro. HELP!
Unread 30-01-2007, 21:30
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Our program team found this a helpful start: http://www.intelitekdownloads.com/easyCPRO/
Unread 03-02-2007, 17:33
AKA: Ronny
Is there any example of someones code for the camera written in easy c pro?
Unread 03-02-2007, 20:11
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Download the "2007 Kickoff Demo Code" on the Intelitek Downloads page - this code tracks the target lights.
Art Dutra IV
世上无难事,只怕有心人.
Unread 03-02-2007, 20:38
Kingofl337's Avatar
AKA: Adam
There is also some demo graphics display camera code is Test Code / Graphics Display.
autotracking and driving with Easy C??? team877 Programming 4 19-01-2007 12:36
need help with 3dsmax7 and pro desktop Amittt 3D Animation and Competition 3 18-01-2006 08:00
Mechanum Wheels Andy B Technical Discussion 2 10-01-2006 17:41
Drivetrain up and running with stock wheels Mirza95vx Robot Showcase 0 05-02-2005 10:53
Problem with reading and writing EEPROM DKolberg Programming 4 16-03-2004 19:29
