Go to Post Remember, if FIRST is your top priority, you need to look at your priorities. - Billfred [more]
Unread 30-01-2007, 22:08
Ian Mackenzie Ian Mackenzie is offline
FRC #3683
Ian Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond repute
Re: Continuous turret
As much as I'd like to use slip rings (commercial or otherwise) one year - they could be very handy for swerve drives - I'd be a bit worried:
<R58> All wiring and electrical devices must be electrically isolated from the ROBOT frame; the ROBOT frame must not be used to carry electrical current (this isolated ground arrangement is necessary due to polarity reversals that occur under certain operating conditions such as during motor direction reversals).
<R85> Electrical devices must be wired in accordance with Section 8.3 Robot Rules, using commercially available copper wire for all electrical connections. Aluminum (or other non-copper material) wire is prohibited. For examples of acceptable circuit designs, please see the 2007 Robot Power Distribution Diagram.
I think you could argue that a commutator involves using the robot frame to carry electrical current, illegal according to <R58>; unfortunately, 'frame' isn't defined. Even if you argue that the commutator isn't part of the actual robot frame, but a separate, isolated piece, I certainly think a commutator is an example of an electrical connection using something other than copper wire, in contravention of <R85>.
Turret or No Turret? Leo 1529 Technical Discussion 5 16-01-2006 15:47
Turret Supplies? Andrew Blair Technical Discussion 2 15-01-2006 21:20
The Continuous Letter Sentence Game xtremedarkness Games/Trivia 38 11-02-2005 10:12
pic: Turret 1 CD47-Bot Robot Showcase 1 13-02-2004 01:10
Cable rigging: Cascade vs. Continuous Madison Technical Discussion 2 19-01-2004 23:23
