Go to Post The GDC probably took bets on how many posts they could get off of a random CAD render, and bonus points for how many people go insane from thinking about it! :yikes: - gallo26 [more]
Unread 30-01-2007, 23:28
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Evaluation Board Gyro
It should work if you just wire the twist pins, but go ahead and do the temp pins two. Perhaps the board wants power at both. You don't have to do anything (program wise) with the data. Then make sure your program is accessing the correct analog port for the twist signal.
Unread 31-01-2007, 16:50
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Clarification
Just to clarify a couple of things:
The KOP gyro is an ADXRS150. It is already on a small PCB with the necessary components to make it work. I see no reason you would want to use an ADXRS150EB in place of the KOP board.
If you are going to buy additional gyros, get the EB version.
The software interface to the both gyros is exactly the same - it's the same chip.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 31-01-2007, 18:14
LieAfterLie's Avatar
LieAfterLie LieAfterLie is offline
FRC #2028
LieAfterLie is an unknown quantity at this point
Re: Clarification
Thank you very much, StevenB.
SEMPER UBI SUB UBI
Unread 31-01-2007, 18:50
robind robind is offline
FRC #0675
robind is an unknown quantity at this point
So I wired up both the rotation and twist pins (all 6), and I'm still not getting any output. This is on the KOP gyro, btw. Any suggestions?
ah, fixed it. Slight wiring issue (I blame it on the freshman that did a lousy job soldering : P).
Unread 02-02-2007, 15:27
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Hi
Team 1629 requested the KOP GYRO by email, but all we got was a set of Target Light lamps.
I swear I saw an email/blast or something about what to do if the gyro didn't turn up, but I've searched and can't locate it.
Has everyone else received their Gyro?
EDIT: I tried the obvious of re-emailing FIRST, but the sensor address is bouncing
Remote host said: 550 <sensors@usfirst.org>: Recipient address rejected: User unknown in virtual alias table
Phil.
Phil Malone
http://www.GEARSinc.org
Unread 04-02-2007, 11:48
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
We got ours with our light, so yes you should e-mail them.
I know it's an answer in the Q & A, I'll try to find it later today and post it up here.
Unread 04-02-2007, 12:02
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
Originally Posted by PhilBot View Post
Hi
Phil.
http://forums.usfirst.org/showthread...highlight=gyro
Originally Posted by FRC Q&A
In response to question #1, all sensors will have been shipped by Monday, January 29. If you do not receive the accelerometer/gyro boards by February 1, please contact FRCparts@usfirst.org.
In response to question #2, additional sensors to those provided in the kit are permitted. However, sensors not provided with the Kit of Parts should be evaluated using <R47> and <R48> and installed per <R72>.
Ricky Quinones
Director of Sales - VEX Robotics
Unread 07-02-2007, 18:27
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Originally Posted by TubaMorg View Post
programming wise if you use the AnalogDevices gyro it will be the same. I believe Kevin Watson's code is set to use both the 150 deg/sec and the 300 deg/sec gyro, if that is what you are using. If using EasyC I think you need to scale the output by a certain factor to get the correct output. It depends on which model you are using.
From our experience, if using Kevin's code, you'll probably also want to narrow the gyro deadband if you're using a 300 deg/sec gyro (else it won't see small rotations).
Unread 08-02-2007, 08:52
haroony341's Avatar
haroony341 haroony341 is offline
FRC #0341 (Wissahickon HS & NMTCC) FRC#2234 (The Episcopal Academy)
haroony341 is an unknown quantity at this point
Send a message via AIM to haroony341
we used the gyro ordered from FIRST and wired just the 3 twist holes to pwms, but we get the same random reading if the gyro is attached or not. im assuming this is a soldering issue. but what else could it be? do you need to wire the Temp (R)?
Drexel University Class of 2009 -- Computer Engineering
Team 341 Miss Daisy // Wissahickon High School @ NMTCC
http://www.team341.com
Team 2234 // The Episcopal Academy http://www.ea1785.org/robotics
Unread 08-02-2007, 11:31
kaszeta's Avatar
You don't need to wire them up to the Temp.
It's probably a soldering issue.
Unread 11-02-2007, 13:08
haroony341's Avatar
i hooked up the gyro to an oscilloscope and it worked fine there. and the soldering looks ok too. what exactly would we be looking for when the gyro is connected to the RC with WPI?
Lights in Joystick board or control board rcubes85 Control System 15 26-02-2005 23:40
Gyro magical hands Programming 2 14-01-2005 20:57
Perf Board = BS2-IC Carrier Board? indieFan Electrical 2 16-09-2004 08:28
Gyro archiver 2001 2 23-06-2002 23:11
