Go to Post I find it quite amazing that this thread has been continuously active for more than two years. - Stephanie [more]
Unread 30-01-2007, 22:37
Transformers Transformers is offline
FRC #2260 (Transformers)
Transformers is an unknown quantity at this point
Master Links Needed
If anyone can help me find some master links for the chain provided in the kit it would be a huge help and save me much time. If you can, thank you in advance.
As for posting this in the motors section, it seemed relevant. If you have a problem with it I'm sorry but there is no need to freak out.
Yes, Spanky
Unread 30-01-2007, 22:41
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Master Links Needed
Try mcmaster.com then search for roller chain and look under accesories. Pitch is 35 (3/8ths)
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 30-01-2007, 22:42
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Try a "real" auto parts store, such as NAPA, Car Quest, etc. Or a lawnmower shop. Or Ace hardware. They are readily available in most towns.
edit: yeah, you are looking for "number 35 chain" master links
Unread 30-01-2007, 22:43
wow thank you even those specs help. thanks!
Yes, Spanky
Unread 30-01-2007, 23:20
That helps too. yea all we really have is ace hardware. Thanks
Yes, Spanky
Unread 30-01-2007, 23:27
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
You can also get them at Lowe's
Unread 30-01-2007, 23:36
fsracer fsracer is offline
Mentor team 3137
AKA: Frank Saladino
FRC #3137 (Thunderbirds)
fsracer is a name known to allfsracer is a name known to allfsracer is a name known to allfsracer is a name known to allfsracer is a name known to allfsracer is a name known to all
Forget the master links.
Buy a # 35 chain breaker. They are quicker, and the chain will not fail at the master link.
Any Go kart parts supplier has them for $20 or so.
Be sure to get the one made for # 35 chain and not the universal one.
Good luck!
Mr. S
Team 353
Unread 30-01-2007, 23:42
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Good luck!
Mr. S
Team 353
Wouldn't you still need to reattach them after breaking them? via master link or re-riveting?
Kevin Li
596 - Sciclones
Master Code 11? SteveO Programming 5 22-04-2005 19:48
Master Code? HolyOne207 Programming 4 12-01-2005 22:32
Master Machinist 157#1Driver Career 0 13-01-2003 21:17
my master plan (mwahahahahaha) archiver 2001 4 23-06-2002 22:04
Webcast Links! Post links here! activemx Championship Event 0 21-04-2002 22:33
