Go to Post Now, I either need to convince Mike Martus to start the webhug early (or move it back 1 hour), skip the webhug, miss the first part of the presentation, or just clone myself. - Andy Baker [more]
View Poll Results: Wood or Aluminum
Wood 19 14.96%
Aluminum 108 85.04%
Voters: 127. You may not vote on this poll
Unread 30-01-2007, 23:54
ThomasP's Avatar
ThomasP ThomasP is offline
FRC #1255 (Blarglefish)
ThomasP is just really niceThomasP is just really niceThomasP is just really niceThomasP is just really nice
Send a message via AIM to ThomasP
Wood vs Aluminum
If you had to choose between wood and aluminum where both would cost the same and have the robot ready within the same period of time, which would you choose and why?
Please don't vote for either and just say "because it looks cooler", I'd really like some technical answers to this to give the team all the information they need to make a good decision.
Unread 31-01-2007, 00:01
Zoheb N Zoheb N is offline
Captain
FRC #0118 (Robonauts)
Zoheb N is just really niceZoheb N is just really niceZoheb N is just really niceZoheb N is just really nice
Send a message via AIM to Zoheb N
Re: Wood vs Aluminum
I would personally go with aluminum from the stand point that if your robot does get rammed alot during competition you have the ability to beat it back into shape where as if you have it made out of wood it will chip away and become irreplaceable
2004 Lone Star Engineering Inspiration
2005 Denver Regional Winner
2005 Denver Radio Shack Innovation in Control Winner
2005 Lone Star General Motors Industrial Design Winner
2005 Lone Star Regional Winner
2005 Lone Star Regional Chairman's Winner
Unread 31-01-2007, 00:03
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Aluminum is much easier to work with in my opinion and it is much lighter and comes in many more different shapes. Also in some tight situations, if you really need to, you can feed your wires through aluminum if you are using box aluminum. It is also a little more flexible from my experience.
The only downside is that on wood you get splinters and with aluminum you get huge slices on your fingers with sharp parts if you aren't that careful but overall aluminum wins by a landslide.
Pavan.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Last edited by Pavan Dave : 31-01-2007 at 00:09. Reason: spelling...FF doesnt catch Quick Reply box automatically
Unread 31-01-2007, 00:07
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Aluminum is usually a better choice, as you can do more with it. An aluminum tube can withstand a very large load, and weigh very little compared to a solid wood board of the same strength.
Wood may be easier to work with if you have few machine tools, although clever design can get you very far with sheet, angle and tubular aluminum and a few hand tools. Rivets are strong, light and inexpensive. If you have access to a sheet metal shear and brake, you can make many aluminum parts that are strong, light, and rigid. As an example, we made a prototype ramp section that would weight less than a pound per linear foot, and can support 400 lbs over a two foot span.
Both wood and aluminum have been used very successfully to build airplanes, so it should be obvious that they both can be used to build strong, light structures, if the necessary design work is done.
Unread 31-01-2007, 00:08
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Aluminum provides much greater flexibility in your design. Aluminum comes in many stock shapes and varieties, and can be used for just about anything (frame, axles, gears, rivets, bolts, sprockets, wheels, etc.). Aluminum can also be bent and re-shaped, while wood breaks. Aluminum also provides more options for mounting, such as welding and riveting.
Unread 31-01-2007, 00:26
underwood's Avatar
underwood underwood is offline
lead machinist
AKA: alex
FRC #1072 (Harker Robotics)
underwood is an unknown quantity at this point
aluminum
ever tried to make a wooden sprocket?
My Famous Last Words Will Be:
"I dunno, press the button and find out."
If life gives you lemons, find someone who's life has given them vodka and have a party.
"Bad artists copy. Great artists steal."
-Pablo Picasso
"Anyone who has never made a mistake has never tried anything new"
-Albert Einstein
MECHANICAL MONKEYS RULE!!!
Unread 31-01-2007, 00:37
ThomasP's Avatar
Originally Posted by underwood View Post
aluminum
Well, I'm sure someone has, I was mostly referring to the robot frame and arm though.
Unread 31-01-2007, 01:18
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
The only use I can think of for wood in robotics is to offer a noncunductive surface for mounting electronics.
For everything else, aluminum. (2024, 7075, and 7068 are hard to beat, as well as the alloy everyone loves, 6061)
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 31-01-2007, 01:42
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Gabe, my welder hates you. Seriously, any of the aircraft grades are nigh impossible to weld well. Thus we use 6061 for the majority of our parts. We're actually looking at thin wall steel for next year to make the welding even easier.
At any rate, on topic, wood is just too fracture prone under shock loading for my taste. Aluminum will bend, but might be usable or salvageable after it yields. Wood doesn't yield, it breaks. That said, it can have its uses in structural parts of the robot. Contrary to the prevailing opinion here, I think wood is a rather lot easier to work with than aluminum, as it is amenable to all sorts of hand tools and, well, woodworking tools. The strength to weight ratio of wood is more or less comparable to aluminum as well. So understanding the main limitations of wood, there are still places on a robot where it might be preferable to other materials.
Unread 31-01-2007, 01:44
run the trap!!!
Team Role: Human Player
Which is better? What I think you should be asking is "what am I building"
There are plenty of good uses for wood, and if used correctly it can offer comparable strength and durability to aluminum.
Our team needs to make a fairly large 5/8" thick plate this year for our tube grabber. After extensive discussion we determined that Baltic birch plywood (a marine grade plywood) would be perfect for this application. The wooden plate would be lighter then the aluminum and would offer reasonable strength and rigidity.
-Philip J. Fry
Unread 31-01-2007, 02:07
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
For many applications, aluminum can and should be the preferred choice.
However, I can think of several circumstances where high-quanity wood can be successfully used on the robot, and might even be a much better choice than aluminum. I can think of a few prominent teams who use wood chassis' with great success.
Art Dutra IV
世上无难事,只怕有心人.
Unread 31-01-2007, 02:26
dtengineering's Avatar
AKA: Jason Brett
Each has their uses, but if we had to choose just one then I would go with aluminum for many of the reasons listed above.
Fortunately I don't and we have used wood for everything from a chassis (2004) to an arm (2005) that was 5' long, weighed 3 pounds and supported two PNW regional judges as well as the Xerox Creativity award they gave us for it, to the CNC machined turret, hand-turned 8" loader pulley, and maple bearing blocks and mini-bike motor mounts we used last year.
This year... well.... it is definitely coming back in our lift and end effector... but now that the challenge has been raised... hmmm... wooden sprockets... where can we fit one of those in to the design?
Don't be too quick to write off wood... when dealing with solid circular or rectangualar cross sections (no hollow tubes, etc.) it has one of the highest stiffness to weight ratios of any material, and in structural applications it is more fire-resistant than steel. (Uninsulated steel, that is... it gets hot and goes soft while the outside of the wood chars to form an insulating jacket.)
But yeah... for the robots... Aluminum if I had to choose.
Jason
P.S. Why, YES... my favorite airplane IS the Mosquito! How did you guess?
Unread 31-01-2007, 06:40
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
aluminum
http://www.chiefdelphi.com/media/photos/26540?
Unread 31-01-2007, 15:51
Andy A. Andy A. is offline
Getting old
FRC #0095
There have been many highly successful robots that are made primarily out of wood. Contrary to popular opinion, the wood doesn't 'just break'. It will flex a great deal before deforming. When it does deform, it is typically a very localized thing. Imagine ramming an aluminum bar hard enough to plasticly deform it. The entire bar is now bent. Ramming a piece of plywood might dent, even break through, the area that was hit, but the rest of the wood will not be affected.
Is it the right material for every application? Of course not. But it does have it's uses, and for the team with limited tooling it's a godsend.
Team 95 has been using wood, mostly 1/2" Baltic plywood for years with great success. Heres a sample of four 95 robots, 1998 through 2004 that used at least some wood.
http://www.lrt-uppervalleyrobotics.c...es/page_1.html
http://www.lrt-uppervalleyrobotics.c...s/page_17.html
http://www.lrt-uppervalleyrobotics.c...es/page_3.html
http://www.lrt-uppervalleyrobotics.c...es/page_2.html
Many of those robots all preformed a similar task; picking up up balls off the ground. Rather then reinventing the wheel, the team chose to adapt an old design. By 2002, it had been pretty well perfected and the 'popcorn popper' was the result. A few more similar robots have been made since, all with the same frame layout and materials. The wood allows for a frame that is quick to produce, protective and just the right amount of flex. It could have been done with aluminum, sure, but plywood did everything just as well.
Use the material you are most comfortable with and best able to manipulate.
-Andy A.
Unread 31-01-2007, 16:01
Liz Smith's Avatar
Liz Smith Liz Smith is offline
believes in robots
AKA: Pika1579
FRC #3940
Liz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond repute
Send a message via AIM to Liz Smith
I heard what you said about not just saying "it looks cooler", but I do consider that to be a factor as well. Both aluminum and wood can make sucessful robots, but I think that most people think of metal as being stronger than wood. With this in mind, I think that if two robots had the same skills, and the same W-L record, an aluminum bot would be picked for an alliance over a wood bot.
Alumna of 555 Mentor of 3940
Volunteering since 2004: Say hi to me at events!
Applications Engineer
AndyMark, Inc.
Using Wood fredliu168 FIRST Tech Challenge 1 30-10-2006 21:46
pic: Wood as an David Brinza Extra Discussion 4 08-04-2006 19:29
pic: 1346 - Wood is Good dtengineering Robot Showcase 21 14-02-2006 02:15
Realistic Wood Corporat 3D Animation and Competition 6 07-02-2006 19:41
Allowed wood types kmcclary Off-Season Events 4 26-10-2001 01:04
