Go to Post If you are playing foozball and your ball bounces back out of the goal, do you expect the table's manufacturer to fix it? No - you groan and keep playing! Nothing's different here. Like Dave said, it's part of the challenge of playing the game. - petek [more]
View Poll Results: Which would you take have on your robot with the conditions in the post?
The compressor and one accumulator 10 58.82%
Four accumulators 7 41.18%
Voters: 17. You may not vote on this poll
Unread 31-01-2007, 00:35
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Compressors vs. Accumulators
This a question I had after a discussion with some people on AIM. Since the compressors are heavy and are technically unnecessary weight (since you don't need one on the robot), what would you go with and why?
A compressor and an accumulator or no compressor and four accumulators? Explain.
Also since it does depend on the amount of pneumatics you have on your robot and how much air you use in a match, lets for the sake of this discussion say that with autonomous, you can run a successful match with four full accumulators.
Rule clarification:
Originally Posted by 2007 Manual
<R101> The compressor may be mounted on the ROBOT, or it may be left off the ROBOT and used
to pre-charge compressed air in the storage tanks prior to bringing the ROBOT onto the
playing field...
Pavan.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 31-01-2007, 06:45
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Re: Compressors vs. Accumulators
Is "One compressor, four tanks" an option? A lot of teams will be using that option, but we are using one compressor, and two tanks.
We are using suction to "grab" the tubes, and there just isn't enough air in the tanks to keep a venturi suction going while running all of the other pneumatics.
Unread 31-01-2007, 07:07
Pavan Dave's Avatar
Busy in College
No, because this is not robot particular question I am asking. I am asking if your robot could run a match with some air remaining with four accumulators, would you just use four accumulators, or would you use one accumulator and the compressor?
If this was a robot specific question I would have to agree with you though.
1745 - 118 - ΔΕΨ
Unread 31-01-2007, 07:33
Billfred's Avatar
Billfred Billfred is offline
If I could run a match on accumulators with an adequate safety margin, I would. But if I had any doubt about their ability to hold out, particularly with their use in a critical area like drive, I'd look at the compressor.
Unread 31-01-2007, 07:45
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
I decided this year, I didn't want a pneumatic system anywhere near our bot. I hate the weight of the compressor, but I hate all the goofy rules required to charge a bot without a compressor on board even more. It turned out we needed pneumatics so I decided to go with the comp on board this year. Reason is last year they made the charging system rules very strange and they do that every year. It becomes very stressfull before a match when that portable compressor setup doesn't work, or pass the "todays new inspection rules". I think from now on if I go with pneumatics, the compressor will be on board. Unless theres a serious weight issue. Plus these kit systems always leak, you need a constant supply if you use them much.
www.179swampthing.org
Unread 31-01-2007, 07:58
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
I agree 100%. I voted for the compressor being on the robot. In my experience the value of having the compressor off the robot is overshadowed by the murky rules given to inspectors. No joke: at one regional the inspectors made us connect our off robot compressor to a Spike relay.
Unread 31-01-2007, 09:46
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Consider the compressor to be a 5 lb insurance policy!
Using pre-charged accumulators Peter Matteson Pneumatics 8 14-02-2006 10:42
WARNING - Keep those compressors cool or you may be slimed!!!! Elgin Clock Pneumatics 14 24-02-2004 06:44
Two Compressors Jay H 237 Pneumatics 16 16-02-2004 20:55
