Go to Post I'd rather have our robot not fall over. - Andy Baker [more]
Unread 31-01-2007, 00:40
Brad Voracek Brad Voracek is offline
.999~=1
FRC #0399 (Eagle Robotics)
Brad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of light
Send a message via AIM to Brad Voracek
399's ramp release.
http://www.youtube.com/watch?v=qYIqy0AYyGg
Sorry for the bad quality, long story.
This is our current prototype for the ramp release... It's really hard to drive up right now, it needs reinforcing... and probably a wall. It's also not our final design, we have another group working on a lift that will actually lift the robot, this is just less parts. We aren't sure which will weigh more yet. The whole thing falls down after pulling a pin, which we plan do just do with a servo. Lexan is being used to spring it out, it's pretty sweet.
.999~ (Repeating) is equal to one (1).
Team 399 - Eagle Robotics
Unread 31-01-2007, 00:51
Kyle's Avatar
Kyle Kyle is offline
Mike Wade, RIP You will be missed
AKA: Kyle Rice
FRC #0365 (MOE)
Kyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond repute
Send a message via AIM to Kyle
Re: 399's ramp release.
That looks good so far, are you going to have any control over the ramp once it falls down?
2007 Championship Chairmans!!!!! 8 years in the making GO MOE!
Facebook
Unread 31-01-2007, 00:53
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Looks sweet. Two questions...
1) How much does that ramp weigh?
2) What material are you using?
Our team has something like that planned, but we are going to stress on weight depending on what we use.
Unread 31-01-2007, 01:23
.999~=1
As of right now with this design there is no plan to. the robot would have to climb up and be supported on the platform, which could be a problem. Like I said we have another design being worked on which would be just the ramp portion, and would be powered to lift the robots. They still have to climb the ramp, but not the entire way, and we think it may be a little easier on the robots.
Right now it weighs around 14 pounds. We're just using some sheet aluminum (sorry I don't know what exact thickness etc, I'm technically a programmer ;P) with angles for supports. A robot can drive up it fine (as in it can support it) but it's a little small and tough to position yourself on.
But yeah, weight is definitely an issue for us right now... we're trying to do a little bit too much. All is well though.
Unread 31-01-2007, 02:08
clean399's Avatar
clean399 clean399 is offline
Mr. Clean
AKA: Nick Hayes
clean399 is a jewel in the roughclean399 is a jewel in the roughclean399 is a jewel in the rough
Send a message via AIM to clean399
We are using sheets of .050 thick aluminum backed with 1x1x.125 angle aluminum all riveted together with number four rivets which hold around 650 pounds of sheer force.
Unread 31-01-2007, 22:21
d.courtney's Avatar
d.courtney d.courtney is offline
AKA: David
FRC #0781 (Kinetic Knights)
d.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud of
whats your ramp angle?
Unread 31-01-2007, 22:49
clean399's Avatar
Mr. Clean
AKA: Nick Hayes
approximately 19 degrees and it is around 12 and a half inches tall
Unread 03-02-2007, 18:41
Jaybee1405
Posts: n/a
sorry for the late reply, but can you further elaborate on the lexan "spring"
just wondering...
Thanks
Unread 04-02-2007, 14:54
.999~=1
Well, basically we found out you could use lexan as a springing mechanism, if you bend it, it'll snap back into shape. We connected the lexan to one part of the ramp, and bent the other part down (it's hinged). then we stuck a pin in the bottom of the ramp... there's a lot of force on that pin, from one piece of lexan (we just cut some small strips). In the video there were two pieces... Pull the pin, then the lexan snaps back into a strip, forcing it to unhinge.
Sorry for the rough explanation, it's kind of hard to explain. Just go get a piece of lexan, bend it, then release one end and watch it snap back. You can use it like a leaf spring, works great.
Unread 04-02-2007, 15:44
Peter H Peter H is offline
FRC #1606 (Dragons)
Peter H is an unknown quantity at this point
"pull the pin" - note that <R46>, as amended by Team Update #3, prohibits solenoids. No rationale, just the prohibition.
We are using expanded aluminum supported by aluminum angles along the edges. Light; mostly open space. Is it OK to let the ramp crash down? We plan to lower the ramp gracefully using a motor unwinding a support wire, with a coil spring assist.
Unread 04-02-2007, 16:04
Please re-read--it prohibits "electric solenoid acutators". Nothing prohibits using small pneumatic cylinders or servos, or even a motor, for pulling a pin.
And yes, the ramp may crash down.
Unread 04-02-2007, 16:09
.999~=1
Yeah, we plan to use the dual action solenoid to pull the pins, one for each side. We tried using servos but the way we had it rigged currently the servo didn't have enough power to pull it (I hooked it up through a vex controller, still uses 7.2v batteries and everything). Although the solenoid is heavier than the servos, it will more than likely be more reliable.
Unread 04-02-2007, 16:12
GVDrummer's Avatar
GVDrummer GVDrummer is offline
AKA: Jake Hall
FRC #0216 (RoboDawgs OTL)
GVDrummer is on a distinguished road
Send a message via AIM to GVDrummer
Looks really nice and simple!!! although I couldn't tell what is was made out of so can it take that kind of impact repeatedly?
Unread 04-02-2007, 16:24
.999~=1
right now it's aluminum, and it still looks fine after ~20 pulls. We think it's a tad too heavy so we're trying some other stuff right now. We also lowered the amount of lexan to one piece, so it doesn't slam as hard. it goes out a little slower and is less violent.
You should see our miniature version of this though, that thing really slams out. All of our mentors were worried about the safety of the large one, lol.
Unread 04-02-2007, 22:40
Jaybee1405
Posts: n/a
interesting.... nice idea
thanks for the explanation and good luck in the competition
Motor Ramp Up/Ramp Down Function Tom Bottiglieri Programming 12 03-12-2006 23:31
Release Forms??? jakey General Forum 3 28-02-2006 13:08
To ramp, or not to ramp? phrontist Rules/Strategy 27 26-01-2006 17:56
Release Form kjohnson Championship Event 4 27-01-2004 16:21
openFIRST Release -- 'Twas the Release Before Christmas Timothy D. Ginn FIRST-related Organizations 3 25-12-2003 23:44
