Go to Post It's rather simple: you start with a block of solid and remove material until you just have the robot left. Kind of like making a sandcastle. Only harder. - petek [more]
Unread 30-01-2007, 23:29
fsracer fsracer is offline
Mentor team 3137
AKA: Frank Saladino
FRC #3137 (Thunderbirds)
fsracer will become famous soon enoughfsracer will become famous soon enough
Banebots Return policy
Teams be aware that Banebots does not accept returns on parts.
We could not find this policy clearly stated on their site.
Team 353
Unread 30-01-2007, 23:46
EnderWiggin's Avatar
EnderWiggin EnderWiggin is offline
07' Co-Team Leader
AKA: Carl Partington
None #0610 (The Coyotes)
EnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud of
Re: Banebots Return policy
They will let you return defective parts though.
Basically just run one of their gearboxes for a minute, wait for it to break, return it.
Unread 31-01-2007, 00:00
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
The funny thing is that this is what they said to us. They were so confident that they will not break that they told us if (when) they fail we can return them... Lets say there may be some "stress testing" with an arbor press involved..
edit: that was a joke... but their return policy frustrated us the other day, the more people that call them and outline the problems we have with their products the sooner they will take action. We called them, explained the design flaw being discussed here and linked them to the discussion about their transmissions. Hopefully they will take all this into consideration and allow for returns.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 31-01-2007, 00:10
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I don't think we want to put a company out of business here guys. There are people working on a solution. Let's see what they come up with before we go returning them all.
Unread 31-01-2007, 00:13
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I'd hold off on jumping off the Banebots ship and trying to return your "defective" parts just yet. FIRST and Banebots are currently working on a fix for the 56mm gearboxes, and I'd wait to see what they can come up with. Besides that, it is not yet clear (as Dr. Joe has pointed out) how widespread this problem is, and whether we can expect these transmissions to fail in the field, and under what conditions they will.
As for the 36mm and 42mm transmissions, they are still usable given certain tolerances in your design.
Unread 31-01-2007, 00:51
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
FIRST is large enough now that suppliership is a big deal for companies like BaneBots, and I think they are taking the problem seriously and will do all in their power to rectify it, fast. It seems that the only widespread problem is with the carrier plates, and the troubleshooting/fixing process is moving forward on many fronts with the help of many teams.
Maybe it's an opportunity to pursue new avenues of engineering that aren't always explored in FIRST - teach and learn about different types of carbon steel, FEA, heat treatment, EDM, etc. Teams with these resources can share information and parts. Teams without can pioneer simpler, low-tech solutions. And in the process, a product line will be improved by its customers - I can't think of a better way. Maybe this is the real challenge...that stuff with the tubes and rack is just for show.
</SPEECH>
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Unread 31-01-2007, 00:58
07' Co-Team Leader
I don't understand why everybody on CD is so quick to defend FIRST/Banebots. We all payed for these gearboxes (whether or not you are using them is irrelevant) and we got ripped off. This is a downgrade from last year.
It looks to me like Mr.Banebots has some friends inside FIRST (Canadian sponsorship scandal anybody?) and is trying to make a quick buck. I hope the people at Banebots are reading these threads and seeing these pictures, good job guys
Unread 31-01-2007, 01:22
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
we got ripped off [...] downgrade [...] scandal [...] blah blah blah
Before anybody starts tearing into FIRST and Banebots, let's make sure that we have all the information first. If you've been listening to Dr. Joe, you already know this:
Originally Posted by Joe Johnson View Post
WE STILL DO NOT KNOW THAT THESE GEARBOXES WILL ROUTINELY FAIL IN THE FIELD.
Really. The only field failure of this type that has been reported as of right now is the one reported by Team 166 and that was not a failure where the gearbox was NO-OP but that the backlash was noticeable after 3 hours of hard driving.
I'm not going to blindly defend FIRST or Banebots, but I think it's pretty unreasonable to start making claims about the integrity of the parts and the people who provided them when we still have such a minimal amount of data available. In the mean time, grind your axe somewhere else.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 31-01-2007, 01:45
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Let's slow down here for a bit Carl. I, as well as many others on the forum have used these banebot gearboxes for other projects and they worked great. When you get a chance, sit down and read through all the posts Dr. Joe has been making about these gearboxes and the data he is sharing with us. You will learn something new that you may be able to use in one of your future projects.
Unread 31-01-2007, 01:50
clean399's Avatar
clean399 clean399 is offline
Mr. Clean
AKA: Nick Hayes
FRC #0399 (Eagle Robotics)
clean399 is a jewel in the roughclean399 is a jewel in the roughclean399 is a jewel in the rough
Send a message via AIM to clean399
Ok I have heard of this problem numerous times I was wondering if anyone was running the two motor conversion kit on their gearboxes.
dtengineering's Avatar
AKA: Jason Brett
First of all, YES, some, if not all, of the gearboxes WILL fail in the field.
One of ours already has, with just one CIM, and less than 30 minutes of driving time.
Second of all, there is a big difference between "defending" someone, and saying "Hey, give them a chance."
While I would not wish to be judged by the mistakes that I have made, I think I would be proud to be judged by how I have responded to them. While this is inconvenient and stressful, I have faith that the problem will be dealt with graciously and professionally... but not instantaneously.
Jason
Unread 31-01-2007, 08:04
Billfred's Avatar
Billfred Billfred is offline
[remark="smart"]Well, not everybody--obviously, you're not defending them at all! [/remark]
There are efforts underway to get these gearboxes tested under particularly rigorous controlled conditions. Details are coming; in the meantime, as Dave was quoted as saying, play smart.
Unread 31-01-2007, 08:36
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
We ordered 3 additional gearboxes, for 5 total, because we knew that we needed 4.
One of the 3 sent to us was defective out of the box. Something inside was binding, and never worked properly.
As far as our other 4, they seem to be OK for the moment. We did some no-load tests and those seemed to be OK... Our wheels should be mounted today so we can do some more testing.
Jacob
School Shop Policy Ryan Morin General Forum 39 06-03-2005 22:07
**IMPORTANT FIRST EMAIL BLAST**/Youth Protection Policy Update Wetzel FIRST E-Mail Blast Archive 14 08-01-2004 11:23
Qotw [12-01-02]: policy on students... Ken Leung Rumor Mill 11 06-12-2002 15:38
Firsts new policy on non disney hotels mnkysp6353 General Forum 3 25-09-2001 15:15
