Go to Post I'm throwing the Unnecessary Sarcasm Flag here. - Joe Johnson [more]
Unread 31-01-2007, 03:05
itay_ms itay_ms is offline
FRC #2215
itay_ms is an unknown quantity at this point
which motor for arm?
i need some help....i didn't know in which motor use for the arm ??
we try 2 keyang motors but when the arm goes up it fall down
Unread 31-01-2007, 04:11
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: which motor for arm?
Two Keyang motors should be able to hold up an arm since they have worm gearing. How much would you say your arm weighs and can it be lightened?
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 31-01-2007, 05:21
FRC #2215
was the worm gearing included in the kit box...?
if yes how does it look? and how am i supposed to use it?
Unread 31-01-2007, 06:51
AcesPease AcesPease is offline
Teacher Mentor
AKA: Bill Pease
FRC #2836 (Team Beta)
AcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud of
The Worm gear is built into the Keyang motors and make them hard but not impossible to back drive. We gear down even more (with gears or chain and sprockets) to slow the motor and add torque.
Bill Pease FIRST Team 2836 Team Beta
Formerly FIRST Team 176 Aces High
WFF 2010
Unread 31-01-2007, 14:39
dtengineering's Avatar
AKA: Jason Brett
It would be helpful to know the length of the arm you are working with and the mass of the arm. It would also help to know the mass of the end effector, or whatever you have at the end of the arm.
Then calculate:
Arm torque=(mass of arm * .5 * length of arm) + (mass of end effector * length of arm)+ (mass of ringer * length of arm)
For a safe operating margin you probably want to roughly double this value...
The Keyang motors output about 10 Nm of torque (7.5 foot pounds) at stall. Two of them working together should deliver 20Nm of torque. If you gear that down about 5:1, you will have 100Nm of torque to drive your arm... that is about 75 foot pounds. The arm will take (very) roughly five seconds to complete one full 360 degree rotation... if you only need 90 degrees of rotation, that will only take one second... which is a bit fast. You may want to gear the motors down closer to 8:1 or 10:1.
Since the motors have worm drive built in to them (notice how the window motors are different from the planetary geared globe and banebots gear motors) they should resist a fair degree of backdrive, and be able to hold you arm in position quite nicely.
Do, however, make sure that you leave some safety margin in there... as your robot drives and bumps around the floor the sudden impact forces on the motors could be quite high and could end up damaging the gearhead on the motors. Use pulleys, sprockets or some other mechanism between your motor and your arm to manage the torque.
Hope that helps,
Jason
Unread 31-01-2007, 14:44
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
I would definitely use the FP motors with the white gearboxes. We've used them in the past on every one of our robots.
Unread 31-01-2007, 16:00
FRC #2215
thank you we will try to use in your advices
Unread 31-01-2007, 22:32
JessR JessR is offline
#0571 (Team Paragon)
JessR will become famous soon enough
Two principles to keep in mind are to make the weight at the end of your arm as light as possible, and to balance the weight of the arm with a spring of some kind. This will allow you to use the motors' power only to move the arm and lift the weight of the playing piece (this year the inflatable rings).
Examples:
If the arm only rotates 90 degrees you could use a gas strut (similar to what holds up the rear hatch of hatchback cars) or compression spring to balance some of the weight. In the USA gas struts are available in auto parts stores.
You could also use surgical rubber tubing that passes around a narrow, large diameter pulley at the arm axle and is attached to the chassis below.
To keep the arm parked in a specific location, From a control standpoint - you could mount a potentiometer or encoder on the arm axle and use a "PID control loop" software to have the software drive the motor to keep the arm positioned as the last potentiometer or encoder location when you took your hands off the joystick or 'on' button.
2004 UTC New England Champions with 716 & 230
Engineering Lead
Team Paragon #571
Which motor is better? master Motors 18 18-02-2006 12:19
Which do you use a spike or a victor on the Bosch motor? Leo 1529 Technical Discussion 2 20-01-2006 20:29
White Paper Discuss: Approx. Motor Spec for Taigene Motor Joe Johnson Motors 2 22-01-2005 16:36
WHich motor to lift and for arm thoughtful Motors 8 25-02-2004 10:34
Which way is Clockwise on Van Door Motor? archiver 2001 3 23-06-2002 23:10
