Go to Post Teams that take care of the little things often have much less trouble with the big things! - dtengineering [more]
Unread 31-01-2007, 13:44
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: BaneBots 42mm Gearbox Pinion
Originally Posted by Gary Bonner View Post
Does anyone know the specs & a source for the motor pinion to fit the BaneBots 42mm gearbox (with 4:1 first stage)? BaneBots is out of stock & doesn't know when they'll be getting more in.
I have one in my hand right now.
It is almost certainly a 15T .6 module, 20deg pressure angle gear.
One source is the banebots transmission itself. You can buy a motor/gearbox and pull the pinion from the motor. In fact, you can get many many pinions from one gearbox because the sun is the same as the planets on a 4:1 planetary stage. AND the carrier pins are 3mm which means you can open the hole up to match the FP or BB motor shaft.
I just tried the usual suspects for other places to buy metric gears have failed me (WMBerg, Stock Drive Products & Pic Design). I think you are stuck with buying a gearbox and stealing the parts.
Joe J.
Team #88, TJ2
Banebots 42mm gearbox: Recommendations for use Joe Johnson Motors 61 01-04-2007 15:28
Banebots 36mm gearbox: Recommendations for use Joe Johnson Motors 2 02-02-2007 17:10
Strange noises from the BaneBots gearbox/CIM combination. PhilBot Motors 5 15-01-2007 11:15
42 mm Banebots Gearbox Hunter Motors 9 13-01-2007 21:52
2007 BaneBots 52mm Gearbox is posted ! Ed Sparks Inventor 3 09-01-2007 07:38
