Go to Post I always thought a trained bio mechanical monkey wrapped in aluminum foil would be the best robot, but every year my team says "No Pete, go sit down." - BuddyB309 [more]
Unread 31-01-2007, 16:13
Schneider Schneider is offline
FRC #0178
Schneider is an unknown quantity at this point
Looking for Nippon Denso Motor connectors
Teams,
Team 178 is looking for extra Nippon Denso Motor Connectors. Only one of these came in the Kit of Parts. They are not available from Innovation FIRST, however FIRST has said that we are "welcome to solicit them from other teams." If you have a connector from your Kit of Parts that you are not using, your assistance would be greatly appreciated. PM me or email MikeASchneider at gmail dot com (take that, spammers!) if you can help. Thanks!
Unread 05-02-2007, 13:26
Japper's Avatar
Japper Japper is offline
FRC #3692 (RocknRobots)
Japper has a spectacular aura aboutJapper has a spectacular aura about
Re: Looking for Nippon Denso Motor connectors
As far as I know we didn't get any connectors in our kit for the Denso or the Keyang motors
and a standard "push on" connector is too wide for the tabs on this connector.
I have been considering soldering wires pig tails to the motor connector tabs and crimping
male "push on" connectors on the end of the wire pig tails.
Also, then filling the motor connector cavity with RTV to act as an insulator and strain relief...
Does anyone know if this is allowed per the 2007 rules?
Please advise
Thanks
Unread 05-02-2007, 13:45
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
I agree that the kit didn't include a connector for the Nippon Denso window lift motors.
We also plan on making connectors to fit on the blade terminals in the integral connector housing on the motor.
Last edited by meaubry : 05-02-2007 at 15:17. Reason: Eliminated reference to Keyang - I wrote incorrect info regarding Keyang
Unread 05-02-2007, 13:52
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
The only relevant rule is this:
<R38> So that every ROBOT’S maximum power level is the same, the motors in the Kit Of Parts
can not be modified in any way, except as follows:
• The mounting brackets and/or output shaft/interface of the motors may be modified to
facilitate the physical connection of the motor to the ROBOT and actuated part.
• The gearboxes for the Fisher-Price, and Globe motors are not considered “integral” and
may be separated from the motors. FIRST will not provide replacements for parts that fail
due to modification.
• The electrical input leads on the motors may be trimmed to length as necessary.
The intent is to allow teams to modify mounting tabs and the like, not to gain a weight reduction by
potentially compromising the structural integrity of any motor. The integral mechanical and
electrical system of the motor is not to be modified.
That rule does not define what a "modification" is. I had heard a few years ago that a team had to get new motors because the judges ruled that they were not allowed to use the motors they soldered onto.
So...please ask at the FIRST QnA; there isn't a definite answer that I can find.
JBot
Aren't signatures a bit outdated?
Unread 05-02-2007, 14:06
Teams did receive two housings and connectors for the Keyang window motors per the KOP Checklist (see pdf page 16).
They came in the terminal bag.
P.S. No Denso motor connectors though. Are you asking about the correct motor? Black or silver case?
Unread 06-02-2007, 00:14
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Originally Posted by Schneider View Post
Teams,
Just to clarify for other potential respondents, I think the original poster isn't looking for electrical connectors, but rather for the plastic coupler that fits onto the motor's output gear. In other words, they're looking for the mechanical output shaft connector, not the electrical terminal connectors.
Our team is using our Nippon Denso Motor and the plastic coupler that comes with it, so we don't have one to offer.
However, if any other teams have the plastic coupler that they're not using, we (just as the original requester) would be glad to work out some sort of equitable trade!
--ken
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 06-02-2007, 00:51
AKA: Dr. Brooks
no team (WRRF)
Yes, it is allowed. Soldering wires to the "push on" connectors
and then potting it with epoxy for stress relief is the thing to do.
Have fun,
Eugene
Please advise
Thanks
Powering the Nippon-Denso Window Motors Excelsior Electrical 1 28-01-2006 22:48
How to get Nippon-Denso Motor walterj Motors 2 05-02-2004 07:20
Nippon Denso Window Motor Specs RichardBCR Motors 13 26-01-2003 07:01
Nippon Denso, how to get a spare caffel Motors 1 24-01-2003 14:49
