#61
Re: Banebot 56mm gearbox - double D related
For what it is worth. Joe J. |
#62
This will be a very good set of data to capture the failure and to test possible solutions (with perhaps something to test coming in a few days). Thanks. Joe J. |
#63
Joe J. |
#64
As to the low cycles, I have not observed this particular robot in action but based on other mechanum wheel robots I have seen (I can't get to YouTube from this PC), I am not sure that the loading was infact "low cycles"* In these types of drives, even though the motion of the robot is smooth and continous, the voltages commanded to the motors are often rapid step changes from Full Forward to Full Reverse back to Full Forward -- Again, I am not denying that there is an issue, I am just saying that even though it is direct drive and only 30minutes, it may infact be many many high impact loadings on the gearbox. For what it is worth. Joe J. *Don't jump on me here for burrying my head in the sand. I am have been working this issue since I first saw the joint the day after kickoff. It is only recently that I have been able to get others to join me. |
#66
A target harness approaching RC 40 should be fine. We have run welded axles, 4130 flanges welded with 4130 rod onto 4130 axles for several seasons. We harden these and then temper at 800F. Tempered at 900F, a little softer, the RC is 36 and the tensile yield strength is 161,000 psi. We temper at 800, slightly off the charts, so to speak, but safely above the brittle zone, to get just a little more strength. We have bent these axles in competition with direct robot impact on a cantelevered wheel setup, but have never broken one. Hardening the carrier plates to a value approaching RC 40 is probably just right. Using 4140, or even better 4340, is best for this application. We are using 4130 because this is the material we have on hand. Here is a link to useful heat treatment info: http://www.aerospacemetals.com/steelalloys.html Eugene Last edited by eugenebrooks : 31-01-2007 at 13:41. |
#67
I have just spoken with a materials guy at Delphi. He has recommended 1040, hardened (he advises oil quench since the parts are relatively thin) then tempered to RC 40-42. This is from a source I will call "usually reliable" but I am really out of my comfort zone on this one. Everyone with expertise in this area please feel free to comment. Joe J. Last edited by Joe Johnson : 31-01-2007 at 13:51. |
#68
We are 2nd year team that is planning on using the 56 Trans in direct drive. I am new to posting as well. One possible solution we came up with is to reduce end play by adding a shim between the motor and the drive gear. This pushes the whole mechanism forward so ultimately the drive shaft is set "into" the Double D. We don't have a drive train to test yet. If other teams could make comment or possibly test this solution we be most grateful. We feel the end play is allowing the failure to occur. Also my technical adviser suggests crucible packed with charcoal, bone, or other carbonized material and forge heated for 8 hrs or more. We are concerned about warping the plate. We are opting to not heat treat and have andymark trannies just in case we have to redo the drive train.
#69
As for the shim idea, it sounds reasonable to me at first glance, but I have not had a chance to take a close look at the fit of the motor and gear. I think it would be relatively easy to figure out the shim thickness required, although you'd have to pull the gear off the motor shaft to install it, or change it if it's wrong. Also putting the shim there would be best from the viewpoint of having full gear tooth engagement. Adding the shim in the second stage planetary would allow partial sun gear/planet gear contact. |
#70
An update on the heat-treating front: Yesterday, I tempered the 42mm plate, which seems to be some type of tool steel, and managed to get a significant increase in hardness, although my first attempt was too brittle. I will try again when I get another sample, but in the mean time I tested the 56mm plates too. Unfortunately, they are definitely NOT tool steel and will not harden much without adding carbon. Some data:
56mm carrier before heat treatment: HRA 46.1, 46.5, 46.5 56mm carrier, 950C for 15 minutes, oil quenched: HRA 49.3, 49.9, 49.4 56mm carrier, 950C for 15 minutes, water quenched: HRA 57.1, 57.9, 58.5 (about a C16) It's a slight improvement, but not the C40 we are looking for or even the C23 of the shaft. Case hardening is still an option, but not an easy one. I suspect the solution will be an entirely new plate made of something harder and with a tighter fit for the shaft. I will probably shift my focus to this avenue now, although hardening is still an easy solution for the tool-steel 42mm carrier. Good luck all! |
#71
It would be really nice from the viewpoint of the wear we are seeing....I know in automotive transmissions, once splines start to get loose, they wear out quickly. |
#72
I think the urgency of getting the mat'l analysis is lessened. As to the tight fit, this is going to help some but my theoretical analysis/calculations do not show a significant improvent in this case (nothing like what I expect we need). Here is my current thinking of most likely patches: #1 harder carriers (= to the shaft hardness) address all the 1-CIM cases (16:1 & 12:1) #2 harder (perhaps RC 40-45) carriers plus redesigned joint (e.g. square hole) plus harder (again perhaps RC 40-45) shafts (with mating joint) address all the 2-CIM cases (IF, and this is a big IF, tests show 2-CIMs stress the joint beyond what is done in #1 -- note that motor torque is not the only thing that determines the torque this joint sees, friction is another and it may limit the torque that the joint sees to something close to the 1-CIM number) Stay tuned. Joe J. |
#73
I am not going to try 4140 because I think other people are on top of that and I don't know where to get 5/32" by tomorrow. I should also mention that our original 56mm carriers showed only the very tiny beginnings of deformation after driving around yesterday evening (1 CIM, 12:1), although we haven't done high-cycle testing. Last edited by ZZII 527 : 31-01-2007 at 16:20. |
#74
Dunno what's u, I can see these from my house, I'm at the school now and cannot. Let's try this.
#75
So, unbeknownst to me, one of our mentors has connections and is trying to get the 52mm carrier plate spectrally analyzed to determine alloying materials and carbon content, hopefully by tomorrow or friday if I'm really lucky. I'll keep everyone posted as soon as I have results.
| small banebot motor with 64:1 gearbox | burkey_turkey | Motors | 16 | 29-01-2007 01:48 |
| opening up the BaneBot gearbox to install the CIM motor | jskene | Motors | 9 | 22-01-2007 11:12 |
| Banebot Gearbox | chris31 | Technical Discussion | 45 | 15-01-2007 17:56 |
| Attempting to Cut BaneBot 56mm Shaft | edthegeek | Motors | 6 | 15-01-2007 08:51 |
| 56mm BaneBot Gearbox 15tooth sprockets. Where to buy more? | VEN | Technical Discussion | 4 | 11-01-2007 14:45 |
