#19
Re: Banebots 42mm gearbox: Recommendations for use
Our team is using two of these 256:1 gearboxes for our arm as well, and I've been thinking about heat treating the carrier plate and/or the output shaft. I talked to my materials professor today, and he said it could be done if I knew exactly what kind of tool steel the output shaft and the carrier plate were made of....does anyone know the material specifications? Without these specifications, I imagine we may experience the same sort of fast fracture that others are talking about if I can't figure out the exact type of tool steel.
| Banebots 36mm gearbox: Recommendations for use | Joe Johnson | Motors | 2 | 02-02-2007 17:10 |
| Strange noises from the BaneBots gearbox/CIM combination. | PhilBot | Motors | 5 | 15-01-2007 11:15 |
| 42 mm Banebots Gearbox | Hunter | Motors | 9 | 13-01-2007 21:52 |
| 2007 BaneBots 52mm Gearbox is posted ! | Ed Sparks | Inventor | 3 | 09-01-2007 07:38 |
| Recommendations for 6-amp battery chargers | kiettyyyy | Electrical | 12 | 25-07-2006 01:37 |
