#16
Re: Team Update #5 Posted
I mean seriously. The whole safety glasses thing isn't a tried and true system, and now they want to get even more complicated?? How many people you see in the pits think it's ok to not wear glasses when in the walkways? Is it? Idk. I know my work site has places designated saftey glass zones (inside the yellow and black caution tape - similar to your actual pit) while outside the taped zone (similar to the walkway in front of the pits) are non-safety glass required zones. Sometimes I think some of these rules are just written based on the current OSHA "work force" standards, and are not adapted at all to FIRST Robotics "competition life" ways of working. I mean, safety is the key to it all, there is no denying this.. but who was hurt last year by wearing tinted or reflective glasses? If they were wearing them, they were safe from flying debris in the eyes which is the whole point of wearing safety glasses. We don't mix chemicals in the pits (or shouldn't) and we don't deal with lasers (or shouldn't). So..... http://www.osha.gov/SLTC/etools/eyea...pectacles.html ^---- Most common FIRST Event usage shown, and approved types. Note for the Plano Lenses which is the most common type I see at FIRST events: Quote:
#17
-dave |
#18
In referance to R105 and what was available on the bimba site and responses on the Q and A the manual very clearly states Please check the Bimba web site for available strokes in each bore size. We did and ordered what was available. We are now going to be out time and money due to a serious mistake that was not ours. This is not good When the speed limit sign changes after you pass it -- should you get a ticket for going the old speed limit ?????Last edited by DRH2o : 24-01-2007 at 14:18. |
#19
OK - If this seems obvious - I'm sorry, but I think there is still room for confusion regarding legal pneumatic cylinders - primarily because of differences in the Bimba order webpage and the printed order form. I wish for teams to avoid problems in a few weeks at inspection. I've read the Q & A and the updates and the manual. I've come to the following conclusion:
The PRINTED order form (the last page of the pneumatics manual) lists the ONLY pneumatic cylinders that can be on a 2007 robot. It does not matter that teams can order different cylinders from Bimba's FIRST webpage. It does not matter that the manual is somewhat confusing regarding previous KOP cylinders (<R106>). It does not matter that the Pneumatics Manual states "you may order the exact custom cylinder or rotary actuator you need for the job". It does not matter that the Pneumatics Manual states "please go to www.bimba.com and click on the FIRST link and follow the instructions". Only those cylinders IDENTICAL to those on the FIRST Free Components Order Form (p. 16 of the Pneumatics Manual) and allowed. This means no Parker cylinders at all. This means no 1.5" bore cylinders longer than 11". I make this post because I think lots of teams are going to confuse the PRINTED order form with the Bimba FIRST webpage - even after Update #5. As an inspector, I do not want to be telling teams that their pneumatics are not legal. -Mr. Van Coach 599 RoboDox |
#20
Perhaps you need to look at what's actually written, and not what you (or whoever was responsible for this rule) intended to write. That's the salient point here: what's actually written. Teams are not bound by intent, they are bound by rules. You know as well as I that the officials can't just insert words and concepts as if they should (in someone's opinion) be there. While I certainly recognize that the intent of the rule is very important, if the rule doesn't actually say what it was intended to say, no amount of good intent can take the place of actually fixing the rule. I'm not trying to mislead teams, but you're not helping matters by denying that the rule is potentially inconsistent. If they're misled, it will be because you refuse to acknowledge that there is a slight difference in the way that the rules are worded, and that omission has the potential to cause practical consequences. I'm going to go over this in detail: Quote:
The first sentence of <R105> says there is no overall quantity limit on cylinders. The second sentence says that they must be rated for 125 psi and COTS. So far so good. The third sentence says that you may purchase cylinders. The fourth sentence says that they must be the same as the ones on the form (same part numbers), and obtained from a Bimba or Parker dealer. So, what's that saying? The word "they" bolded above logically refers to the objects in the preceding (third) sentence, namely purchased pneumatic cylinders. Not pneumatic cylinders in general. Not donated, found, stolen or bartered pneumatic cylinders. If you take that fourth sentence to mean cylinders in general (referring to sentences one and two, but not three), its content is logically consistent, but grammatically disjointed. You wouldn't write an essay like that, and you can't reasonably expect people to read like that. Going to Update 5, the relevant sentence references rule <R105>. We have previously established that the text restricting us to cylinders from the form applies to purchased cylinders. If we are operating under <R105>, then the clarification ought to be referring to those items in <R105> which are in question—namely the ones with the restriction that needs clarifying, or in other words, the purchased ones (see sentences three and four). It makes no sense for the update to be referring to all cylinders (i.e. clarifying one of the first two sentences), because it isn't a mere "clarification" to add a new restriction where it never existed before. If the intent was to modify the rule, then you can't just call it a clarification, and expect people to treat it identically. <R106> says, in the first sentence of the first bullet, that prior year KOP cylinders are allowed in addition to those in the KOP. The second sentence of that bullet says that these parts must be accounted for as explained in Section 8.3.4.3 (i.e. account for the cost like any conventional COTS item). Note that the word "purchased" doesn't make an appearance in <R106>. Like I said earlier, there's a subtle point that was overlooked. It's your problem if you feel compelled to take it personally, but the fact of the matter is, given a reasonable application of English sentence and paragraph structure, I can't interpret it your way. The stupid part of all of this, is that it's a tiny change to fix it to everyone's satisfaction. |
#21
Does no one have a problem with this?
We didn't ... we (foolishly, it seems) assumed the rules would be the same as last year, where you had to option to ship or bring the batteries to events.
For us, it's easier to bring the batteries to competition since we drive anyway. Shipping them adds an extra 30+ lbs to the crate, we don't have the original packaging, and we'll be bringing extras in the car anyway - why can't we just bring the original kit batteries too? I guess my biggest problem with this is I don't see why we have to ship two of them. It seems more of a hassle and hindrance than anything. ![]() |
#23
If you want to convince yourself that you are right and FIRST is wrong, then go ahead. If your robot design is impacted by the incorrect conclusions you reach, then that is between you and your team. That is your business. But when you come into a public forum and repeatedly make incorrect statements about the meaning and applicability of the rules, then there is a problem. Asserting statements that contradict the answers provided by FIRST is misleading to those teams that are trying to follow the official rules. More importantly, it is a disservice to those teams that may not yet be experienced enough to understand that answers found here carry no weight with inspectors, judges or referees, and the only official answers are those found on the FIRST Q&A system. Quote:
#24
Ok, so you can buy new pneumatic cylinders, or you can use old ones. Where is the complication? One point doesn't detract from the other.
This lawyering needs to stop! Just build a robot and have a good time. |
#26
Someone said what I was thinking! Finally. This is the complete truth. There is so much, 'if i think this, im right' 'but if i think that, im wrong'. This has to be the worst year, of my three years of experience where people are trying to argue the rule in favor of themself. No, I do not mean that everyone has this intent either. However, the rules simply have not changed alot from previous years, and I will agree that some are unfair, while others are very beneficial. However, there is no need to (stealing from Tom here) lawyer the rules. I can guarantee that if an inspector says that you are in violation of rules, and you try to argue with them without say a specific Q&A response allowing your instance, you most likely will not pass inspection. The rules are not per your interpretation, rather the people who wrote them, FIRST.
#27
Ok, now I'm confuesed - and rather upset.
We just completed our 3 cylinder order from Bimba - ordering three cylinders that are the same bore and stroke as previous kit PARKER cylinders that we already have. Why? Because update #5 makes these Parker cylinders illegal. Update #5 states that: "~ Under Rule<R105>, the only pneumatic cylinders permitted are those that are identical to the Bimba Custom Cylinder Order form found on the last page of the Pneumatics Manual." The FIRST Manual rule <R105> states that: "...additional air cylinders or rotary actuators may be purchased. However, they must be identical to those listed on the Pneumatic Components Order form (i.e. same part numbers), and obtained from a Bimba or Parker Hannifan distributor." The rule is quoted numerous times by the GDC in the Q&A forums. They go further to say: "...and you may NOT use purchased cylinders that are not IDENTICAL to those found on the Custom Cylinders Order Form." (emphasis in original post) PARKER cylinders do NOT have the same part numbers as BIMBA cylinders. They are NOT "IDENTICAL" (the piston shaft, for example appears to be stainless on the Parker and steel on the Bimba). Therefore, Parker cylinders are NOT legal parts. Is there any other way to interpret this? No matter what, I can see that teams will be upset at inspection time - either at having to swap out old Parkers or at learning that they didn't really have to take the rules literally... -Mr. Van Coach, 599 RoboDox PS. I now very much wish that I hadn't deleted my earlier post! |
#28
If the GDC writes a rule, then it's their responsibility to make the rule agree completely with their intent. It is never up to the teams to make up for a shortcoming in the communication of the GDC's intent. In particular, if, on a minor point, FIRST leaves a loophole, an inconsistency or a statement with multiple interpretations, then it stands to reason that FIRST ought to fix it (once it's been communicated to them via the proper channels). And if FIRST doesn't agree that there's a problem, then it's their prerogative to say so—but they do so at their peril, because it might represent a missed opportunity to defuse some of the conflicts that occasionally arise at inspection. Quote:
And I know you don't agree with my rationale. But it's FIRST's job to avoid phrasing things in ways that lend themselves to torturous logic. If the rule were precise in its statement of intent, you wouldn't be having this argument. I can send this to my team's Q&A person, and we'll see what happens. I would like to point out, however, that a flippant response of "see Update 5" doesn't address the issue—it would be nice if the person answering it takes the time to explain precisely why the existing rule justifies their interpretation, and not my own. Quote:
Incidentally, there's another reason why you can't read <R105> in the manner that Dave prefers. If the fourth sentence applies to the first and second sentences, you're in effect saying the following: "solenoid valves, air cylinders, pressure regulators, and connecting fittings" must be "identical to those listed on the Pneumatic Components Order form"Of course, this makes no sense. You can't order valves, etc. from the Bimba form. If you want to cherry-pick the reference to cylinders, sure, that part makes sense (I referred to this earlier)—but then you have the little problem of how to justify the rest of the items ("they"); basically, the rule lacks logical consistency when read this way. (And on top of that, the rest of the fourth sentence would mean that any new fittings, even for the Festo components in the kit, would need to come from a Parker or Bimba dealer; while FIRST is free to mandate this, it's a bit strange, especially considering that other pneumatic parts like tubing can come from any vendor.) Now, instead, read it as if sentence four follows directly from sentence three: "additional air cylinders or rotary actuators may be purchased" and must be "identical to those listed on the Pneumatic Components Order form"Note that this makes sense. Note that this one also doesn't require a leap of grammar to make it work. Last edited by Tristan Lall : 30-01-2007 at 22:02. |
#29
Tristan,
We all are human beings. Our grammar (including yours at times I'm sure) is not always perfect, nor are we. This is why FIRST has established a means for clarification for the 10 section manual that they published: FIRST Q & A. No, the replies to it are not officially in the manual, but they are official clarification on any confusion, and they are from the GDC, thus making them valid. As to your frustrations with the descrepancy between what the rule says and what it means, these men are engineers, not lawyers. A lawyer would spend months of just working on this to get the technicalities correct. These men spend their volunteer free time. I, for one, know that I spend my free time on catching up on Grey's Anatomy and I am grateful to them for contributing theirs to help me. Yes Tristan, it is frustrating when the things that we think should be clear are not. But there is an established mean for fixing the issue in place here. Please use it. And please stop the lawyer-like arguments. From what I've read, the last page or so has been arguing that is doing nothing but getting people confused. And that just doesn't benefit anyone. FIRST is something we do for fun, because we love it. My team has had to remind me of that lately. It should be fun, and we shouldn't torture ourselves over tidbits like words. We're halfway through, so please, everyone (readers and posters) just take a breath and remember why you go to robotics every day. |
#30
Tristan and Dave: There is an easy way to reconcile your views. First, make the change, assuming that it changes nothing else. Then, put Tristan on the GDC for the 2008 game. This will give him experience as to what the GDC goes through every year and (hopefully) give a more grammatically correct manual.
I'm not joking here. "Never criticize someone until you have walked a mile in their shoes." You can't know what the volunteers go through until you volunteer to fill one of their places. |
| Team Update #3 Posted | Katie Reynolds | Rules/Strategy | 26 | 21-01-2007 19:41 |
| Team Update #2 is Posted | geo | General Forum | 1 | 16-01-2004 10:56 |
| Team Update 8 Posted! | Harrison | General Forum | 1 | 30-01-2003 08:08 |
| Team update #6 posted | Joe Ross | General Forum | 6 | 22-01-2003 10:14 |
