Go to Post Wow, I am beginning to feel like a member of the fabled "vast right-wing conspiracy" :) - Jim Zondag [more]
Unread 31-01-2007, 16:53
Idaman323 Idaman323 is offline
In Theory, Our Robot Would Own.
FRC #1706
Team Role: Driver
Idaman323 is an unknown quantity at this point
Catastrophe...
Tonight after school, our robotics was canceled due to illness. When a few of us were sitting in the shop to see if anyone showed up, we heard what sounded like water running. After about a minute or two, the fire alarms go off and we get pushed out of the building. When we turn to go out, there is about half an inch of water running out of the closet with all of our electronics and every other material we have. The water is just pouring out of the closet and out of the back door.
The fire department showed up, the janitor would not let us in, and the robot was getting soaked. After a lot of waiting in 0 degree weather for an hour or so, we were let in... about 1 or 2 inches of water was still flowing out the back door. Everything in the room was soaked in water.
Apparently, the pipe was to the sprinkler system upstairs and when water was flowing through it, the system said there was a fire upstairs and set off the alarms.
We are not sure what we are going to do at this point but right now we arn't going to be turning on our electronics any time soon. As of now.. the robot is wet in the back of a truck icing over.
TEAM 1706
2007 Judges Award, St. Louis (For our amazing ability to have bad luck)
2005 Rookie Inspiration Award, St. Louis
Unread 31-01-2007, 16:59
EOC's Avatar
EOC EOC is offline
AKA: Eric Curry
None #1208 (Metool Brigade)
EOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant future
Re: Catastrophe...
We (1208) are O'Fallon Illinois, not too far from you. You are welcome to our spare parts. Let us know what you need and we will provide what ever we can.
Unread 31-01-2007, 17:01
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Catastrophe...
I would call IFI, tell them of your situation, and hopefully they will fix your parts for free or for a low charge. I doubt anything was ruined unless your robot was on at the time. Electronics won't ruin unless they are running when they get soaked. I would tell you to just open up the controller, victors, spikes, radio, and everything else to dry it off, but doing so voids the warranty. So you have a choice of calling IFI and paying them, or voiding your warranty and making the inspection go a lot worse if they find out that you tampered with your parts.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 31-01-2007, 17:09
Liz Smith's Avatar
Liz Smith Liz Smith is offline
believes in robots
AKA: Pika1579
FRC #3940
Liz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond repute
Send a message via AIM to Liz Smith
Re: Catastrophe...
This actuallly happened in our robotics room my senior year. Fortunately it wasn't during the build season though. We let everything dry out for a few weeks. As I recall everything ended up working fine. I think as long as none of the electronics or anything while they are wet, if they dry out it should be ok. Our main problem was a thick layer of rust on top of most of the metal.
Alumna of 555 Mentor of 3940
Volunteering since 2004: Say hi to me at events!
Applications Engineer
AndyMark, Inc.
Unread 31-01-2007, 17:29
Onward through the fog.
Re: Catastrophe...
This happened to us (water) last spring in the shop and where we store the robots.
I'm so sorry this is happening to you - hope it gets somewhere dry soon and the process of drying out can begin.
In our case as well, the robots dried out and were 'fine'. It took a few days.
I would suggest you contact FIRST and/or IFI and find out your options.
Good luck with this,
Jane
~ Helen Keller
(1880-1968)
Unread 31-01-2007, 17:48
FRC #1706
Team Role: Driver
Re: Catastrophe...
Hmm... bad luck with water and robots? Pics are going up now.. I think we are gonna try to talk to IFI and see what happens.
TEAM 1706
Unread 31-01-2007, 18:14
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
Re: Catastrophe...
With previous experience in the area of cell phones and complete water submersion...
DO NOT POWER ANY ELECTRICAL COMPONENT UNTIL YOU ARE SURE THEY ARE 100% DRY!!!
There still is a chance that they will work.
As RyanN said before, call IFI see what they say.
For reference, I have seen cell phones dropped into pools and lakes while still on. Battery removal as soon as possible and proper time to dry saved these devices.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 31-01-2007, 18:24
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Catastrophe...
We had a similar, but not nearly a severe situation happen to our robot the night before IRI 2005. It was a torrential downpour outside, and the tarp covering our trailer with the robot in it had developed several holes on the drive to Indiana. The next morning we found our robot soaking wet (with about an inch of standing water in the bottom of it) and covered in "tarp dust". We spent several hours that morning going over our entire robot with paper towels, hair driers, compressed air, and WD40. Luckily our electronics board was removable, so it was removed from the rest of the robot, and dried carefully and with special attention. Thanks to some excellent help from Arefin Bari and Tytus Gerrish, we managed to get our robot running again in time for our first qualification match! The worst problems were a blown fuse and some rust on the gears. It never was quite the same robot, but at least it functioned.
Hopefully you can do the same with your robot, and hopefully you can still have a competitive season. Contact IFI and local teams to see what help they may be able to provide. Make sure all your electronics are COMPLETELY dry before powering them. Lubricate anything that can rust. Flush out and drain anything that might still have standing water in it. Be careful, and remember safety first.
If there is anything 116 can do to help you from Virginia, feel free to IM, PM, or e-mail me.
Unread 31-01-2007, 18:26
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Re: Catastrophe...
I used to fly RC planes at a field that had a pond nearby. Two or three times a year somebody would "land" in it. Luckily I only did so once.
When it did happen we'd flush the electronics with alcohol. The alcohol helps remove the water and dries faster. It worked for me anyway
Christopher H Husmann, PE
"Who is John Galt?"
Unread 31-01-2007, 18:28
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Catastrophe...
I've seen people resurrect wet cell phones by letting them sit overnight in rubbing alcohol, so that might just be able to help.
Unread 31-01-2007, 19:02
Dancing_Chuck's Avatar
Dancing_Chuck Dancing_Chuck is offline
AKA: Chuckles
FRC #1111 (Powerhawks)
Team Role: Electrical
Dancing_Chuck will become famous soon enough
Send a message via AIM to Dancing_Chuck
Re: Catastrophe...
Sorry about your luck, guys...
That stinks.
You can dance if you want to, you can leave your friends behind
'Cuz if they don't dance when you want to dance, then they're no friends of mine!
http://video.google.com/videoplay?do...60835799858748
Unread 31-01-2007, 19:13
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: Catastrophe...
Watch out for alcohol + plastic though. I had an mp3 player go through the wash, and in my efforts to get the water out, I immersed it in alcohol. The alcohol completely fogged the front screen, so I imagine it could do equally nasty things to internal plastics as well.
Unread 31-01-2007, 19:37
robotguru1717's Avatar
robotguru1717 robotguru1717 is offline
AKA: Martin Cacan
FRC #1717 (D'Penguineers)
robotguru1717 will become famous soon enoughrobotguru1717 will become famous soon enough
Re: Catastrophe...
I am sorry for your situation. Good luck and hopefully you can get everything together for competition!!
Quote of 2007: "That nub looks cattywampus" -Amir Abo-Shaeer
(fyi there were about 50 nubs on the robot)
Team 1717: D'Penguineers
2008: LA-Regional Winner
2008: SD-Regional Winner
2008: SD-Delphi "Driving Tomorrow's Technology" Award
2007: LA-Semi Finalist
2007: SD-Finalist
2007: SD-Imagery Award
2006: Phoenix Semi-Finalist
2006: Phoenix Regional-Rookie Inspiration Award
2006: LA-Rookie All-Star Award
Unread 31-01-2007, 20:08
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: Catastrophe...
Wow, that is a tough blow to absorb during build season.
We are about 35 miles down the highway from you, just off Kingshighway near I-44, less than a mile from the St. Louis Science Center, where kickoff was held. If you need a place to test-drive your robot please come use our practice field. It is carpeted and has a full-size, low-cost rack. Contact Mr. Dressel (PM me for his email or phone) and let him know when you want to come -- after school and 9-3 Saturdays are always OK. And if we can help with spares to get your robot going again please let me know. As others have suggested , please be very careful to dry electrical components thoroughly before powering up.
PM me here if you want to take us up on the offer. And good luck; I look forward to seeing your team at the St. Louis Regional.
Richard Wallace
since 2003
Unread 31-01-2007, 21:22
Mike Starke Mike Starke is offline
FRCTop25.com
Mike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond repute
Re: Catastrophe...
Please let GRR know if you need any assistance, or spare parts!
