Go to Post Magic Smoke. One whiff and you never forget. - JohnBoucher [more]
Unread 31-01-2007, 19:23
Zoheb N Zoheb N is offline
Captain
FRC #0118 (Robonauts)
Zoheb N is just really niceZoheb N is just really niceZoheb N is just really niceZoheb N is just really nice
Send a message via AIM to Zoheb N
Assembly to Part
Does anyone know if you can change an assembly file to a part file and still have it work for Inventor 11?
2004 Lone Star Engineering Inspiration
2005 Denver Regional Winner
2005 Denver Radio Shack Innovation in Control Winner
2005 Lone Star General Motors Industrial Design Winner
2005 Lone Star Regional Winner
2005 Lone Star Regional Chairman's Winner
Unread 31-01-2007, 19:33
Dancing_Chuck's Avatar
Dancing_Chuck Dancing_Chuck is offline
AKA: Chuckles
FRC #1111 (Powerhawks)
Team Role: Electrical
Dancing_Chuck will become famous soon enough
Send a message via AIM to Dancing_Chuck
Re: Assembly to Part
Well, it works, but once you upload it, you can't edit it until you have started a new workplane, however, you can go back to the assembly drawing, edit that, save it, and then upload the edited part into the part drawing.
In short, yes, but you can't edit the drawing.
You can dance if you want to, you can leave your friends behind
'Cuz if they don't dance when you want to dance, then they're no friends of mine!
http://video.google.com/videoplay?do...60835799858748
Last edited by Dancing_Chuck : 31-01-2007 at 19:34. Reason: Bad grammar/ Word choice
Unread 31-01-2007, 22:08
Captain
Do you know how to convert the assembly into a single part?
What I am really trying to do is get the playing field file that Daniel H came out with Playing field for download
and change the playing field assembly into a single part file.
Unread 31-01-2007, 23:28
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
what about just using the assembly file? i know that in solid works you can import assemblies into assemblies....i am 99% sure you can do that in inventor.
sorry if im missing something but thats what i would do
/forest
Unread 01-02-2007, 07:11
kramarczyk's Avatar
kramarczyk kramarczyk is online now
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Changing an assembly into a part is somewhat unconventional, so what are you trying to accomplish in the end?
And to answer fimmel, yes, you can nest asm files in Inventor.
Mark
Unread 01-02-2007, 07:44
Captain
What I am trying to do is:
One of my teachers at school said he would print it out as a 3D model, but the 3D model printer only takes Inventor part files
Unread 01-02-2007, 08:40
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
Try exporting it as a different type of file, then importing it back into, lets say a new sketch in a new part. You may not even have to export it as something different at all. If you're confused as to what I'm saying, just message me and I'll get back to you tonight when I'm actually sitting in front of the program.
EDIT: Turns out this works (I tried it on inventor 8 though). You have to export the assembly as an IGES, then import it into a sketch. When the part imports, it'll be just the faces in a clear yellow shell, but it's the assembly in a part. It also may cause the computer to run really slow depending on the amount of ram and visual memory you have.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 01-02-2007, 08:48
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
That is a much better problem statement.
Here is the solution.
Start a new part file (ipt). Exit sketch. Select Derived Component and then select the assembly (iam) file to derive. This will combine all your assembly into one part. (Notice that you could also use this method to cut one or more parts from another.)
Save As the derived ipt as STL (or ipt if that is what your teacher wants, but I am not familiar with a 3D model printer that takes Inventor files directly. What machine are you using?)
In Inventor 11 DWF Extension these extra steps aren't required as STL files can be created directly in iam.
Unread 07-02-2007, 01:26
Captain
Thank you so much this really helped me alot.
Assembly? Astronouth7303 Programming 2 12-08-2004 11:30
Importing assembly into an assembly... James Green Inventor 8 22-01-2004 22:17
Assembly Code Venkatesh Programming 1 18-11-2003 17:39
Assembly?!? archiver 2000 2 23-06-2002 22:05
