Go to Post the best way to make things most unfair is to have different rules for different people. - Jack Jones [more]
Unread 31-01-2007, 23:14
Ian_Xodus Ian_Xodus is offline
FRC #1896
Ian_Xodus has a spectacular aura aboutIan_Xodus has a spectacular aura about
Mecanum problems
Ok so
my team is using the AndyMark Mecanum's this year but we are experiencing serious shaking when we try to drive the robot in any way, tank or omni style.
Did we screw up in the building of the wheels?
Anyone have any ideas
BTW we are a basically l\l00l35
Unread 31-01-2007, 23:17
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Mecanum problems
Did you program the controller for driving with mecanum wheels? there is some info here
http://www.chiefdelphi.com/forums/sh...ad.php?t=51528
that should get you started.
Unread 31-01-2007, 23:51
FRC #1896
The issue is not in the programming or at least we don't think its is.
We saw, referenced, and used that link previously.
We think the issue is mechanical.
BTW those with the AndyMark Mecanum's did you put the wheels together so that the writing was on the inside or so that the two plates that you were using would be parallel. By parallel i mean the fit together flat.
Unread 01-02-2007, 00:11
dtengineering's Avatar
AKA: Jason Brett
I take it by "shaking" you mean that you are having a pretty bumpy ride.
Us too. We are modifying some of our electronic mounts to handle an increase in vibration.
If you look at the side view of the wheel you will see that it is not perfectly circular. While a "perfect" omni wheel is perfectly circular (or pretty darn close) that involves careful machining of the rollers.
AndyMark's solution, which is fine by me, was to get "close enough" by using the narrow rollers and wide rollers.... but the "close enough" shows up as vibration.
I am wondering if, as the rollers wear down a bit, they might approach closer to perfect roundness.
Watch the backlash on your BB trannies, if that is what you are using. If it starts to increase then you need to pay close attention to the thread on Banebots 56mm tranny problems.
Jason
Unread 01-02-2007, 02:37
Andy B's Avatar
Andy B Andy B is offline
College Student, Mentor
FRC #1259 (Paradigm Shift)
Andy B will become famous soon enough
Send a message via AIM to Andy B
do you have any sort or suspension for each wheel on your mechanum drive? It may sound odd, but mechanum drives really do need suspension to work optimally. I haven't personally built a mechanum drive bot, but i know anyone who has would back me up on this.
Andy B: College Student, Mentor
Paradigm Shift, 1259 http://www.team1259.org
2004 Midwest Regional: Team Spirit Award Winner, Highest Seeded Rookie Team Award Winner, 4th Seed, 7-1-0 Record , Lost in Quarter Finals
2005 Midwest Regional: Imagery Award Winners, 16th Seed, 5-5-0 Record, Unpicked
2005 Championships, Newton Division: 5th seed, 6-1-0 Record, Advanced to semifinals
2006 Wisconsin Regional: Judges Award, 23th seed, 5-7-0 Record, Unpicked
2007 Wisconsin Regional: 33rd seed, 3-4-1 Record, Lost in Quarterfinals
Unread 01-02-2007, 02:42
AKA: Jason Brett
I don't know about the original poster, but our mecanums seem to be working okay without a suspension... however we have intentionally left a great degree of flex in the KOP frame. We can raise one corner almost an inch and still keep all four wheels on the ground. Given the flat surface we will be running on, it should be fine... I'd be able to state that more definitively, but right now our 56mm banebots are all pulled apart as we are already seeing serious damage to the final stage.
Jason
Unread 01-02-2007, 06:53
FRC #1896
based on what i have seen our ride is much more than just bumpy.
Question for those that have used Mecanum wheels and or those people on team xbot.
How have you gotten your robot to roll so smoothly?
I am starting to believe that we did something like assemble the wheels incorrectly.
Unread 01-02-2007, 07:37
The TechnoKats built one without suspension. It works because the frame has just enough flex to keep all the wheels on the ground. There can be issues if the weight doesn't get distributed relatively evenly, but with a good centering of weight it drives great.
Unread 01-02-2007, 08:31
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Do your rollers spin freely? Our mecanum wheels we giving us a bumpy ride before we fixed the plates and freed up the rollers.
Just a thought,
Jacob
mecanum programming mrmummert Programming 27 28-01-2007 13:45
Mecanum Rob2713g Technical Discussion 13 03-11-2006 14:16
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
Mecanum Wheels TheFerret Technical Discussion 8 16-01-2006 09:23
mecanum patents piotr_boch Technical Discussion 6 25-11-2005 20:03
