Go to Post I wouldn't mind dropping a banana peal or throwing a red turtle shell at other robots, but that's the rules! - SpaceOsc [more]
Unread 01-02-2007, 02:42
dtengineering's Avatar
AKA: Jason Brett
Re: Mecanum problems
I don't know about the original poster, but our mecanums seem to be working okay without a suspension... however we have intentionally left a great degree of flex in the KOP frame. We can raise one corner almost an inch and still keep all four wheels on the ground. Given the flat surface we will be running on, it should be fine... I'd be able to state that more definitively, but right now our 56mm banebots are all pulled apart as we are already seeing serious damage to the final stage.
Jason
Unread 01-02-2007, 06:53
Ian_Xodus Ian_Xodus is offline
FRC #1896
Ian_Xodus has a spectacular aura aboutIan_Xodus has a spectacular aura about
based on what i have seen our ride is much more than just bumpy.
Question for those that have used Mecanum wheels and or those people on team xbot.
How have you gotten your robot to roll so smoothly?
I am starting to believe that we did something like assemble the wheels incorrectly.
mecanum programming mrmummert Programming 27 28-01-2007 13:45
Mecanum Rob2713g Technical Discussion 13 03-11-2006 14:16
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
Mecanum Wheels TheFerret Technical Discussion 8 16-01-2006 09:23
mecanum patents piotr_boch Technical Discussion 6 25-11-2005 20:03
