Go to Post What's this about a robot that they speak of? Are we supposed to build one???? - ryan_f [more]
Unread 01-02-2007, 09:05
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Pneumatic Pressure Switch for EasyC
Have you tried the online window to see if you can fire your relays there?
while ( 1 )
            OIToRelay ( 1 , 1 , 2 , 1 ) ;  //Relay Port 2 FWD
            OIToRelay ( 1 , 2 , 2 , 2 ) ;  //Relay Port 2 REV
This will map the thumb and trigger to forward and reverse of the relay on port 1.
I have attached a precompiled program with the pressure monitoring function.
Plug the compressor relay into Relay Port 1,
Plug a Spare Relay into Port 2,
Plug the pressure switch into I/O port 7.
Joystick into port 1 on the OI
Urgent need for Nason pressure switch!! PLEASE HELP! haverfordfords Pneumatics 12 18-02-2005 02:04
Pneumatic pressure switch M. Hicken Programming 9 29-01-2005 23:35
spike for pressure switch? Rob Colatutto Rules/Strategy 4 23-02-2003 15:42
pressure switch Michael Long Pneumatics 1 11-02-2003 11:21
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
