Go to Post Where we are is only of modest importance. And where we are going is what is really important. - ebarker [more]
Unread 01-02-2007, 10:11
Electrical Engineer
Rookie Year: 1995
Re: Pneumatic Pressure Switch
Originally Posted by Mike Norton View Post
We are going to put everthing on like we had a tank. the only thing we will need is to put a relief valve just so we do bring the pressure up and show that the compessor will shut off
Mike
Mike,
What Al and I are advocating is that you post your question on the FIRST Q&A. This is the best way to remove ambiguities.
Both Al and I will be inspectors at a couple of the regionals and, while we appear to be of one mind on this issue, other inspectors may interpret the rules differently.
By posting to the FIRST Q&A you will be doing the entire community a service by getting FIRST to establish minimum requirements of a vacuum-only pneumatics system.
Regards,
Mike
Mike Betts
As easy as 355/113...
Pneumatic Pressure Switch for EasyC Wompas Programming 5 01-02-2007 09:05
Pneumatic pressure switch M. Hicken Programming 9 29-01-2005 23:35
pressure switch Michael Long Pneumatics 1 11-02-2003 11:21
pressure switch Antonio Pneumatics 10 31-01-2003 03:52
pressure switch piconysm Technical Discussion 5 14-02-2002 23:15
