Go to Post Keep arrogant, belittling and misspelled bragging off these boards. - Mike [more]
Unread 01-02-2007, 10:40
SoD SoD is offline
FRC #2230
SoD is an unknown quantity at this point
Re: Microswitch problem
Printf. And there are 3 plugins in the microswitch right? We connected the yellow one to the upper one, nothing to the middle one, and the red one to the lowest one
Unread 01-02-2007, 10:45
Should be black and yellow, no red at all.
Use only the outer wires at the RC digital input side.
The red is power and used only by devices that need power to work. A switch doesn't need power. It simply connects the signal wire (yellow) to the ground (black) or not to close or open the circuit.
If you have a multimeter you can use it to test that the switch is wired correctly.
Unread 01-02-2007, 10:55
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Thanks! We've got it working!
Unread 01-02-2007, 11:28
SoD SoD is offline
FRC #2230
Darn we now have a new problem
if (rc_dig_in01 == 0)
relay1_fwd = 0;
relay1_rev = 0;
else
relay1_fwd = 1;
relay1_rev = 1 ;
This is the code we are trying to use atm, but we have a problem. When the motor works foward, and i press the microswitch, it changes from 1 to 0 and the motor stops working. But when the motor is working backwards, and I press the microswitch, the microswitch turns to 0 but the relay1_rev remains 1 ;s
Whats wrong?
Unread 01-02-2007, 11:34
Andrew Morris's Avatar
Andrew Morris Andrew Morris is offline
Oh hey, it's build season!
FRC #0177 (Bobcat Robotics)
Team Role: Student
Andrew Morris will become famous soon enough
What motor? You haven't mentioned a motor before.
Andrew
2010 Newton Division & Championship Winner w/ 67 & 294
2009 CMP Champion - Newton Division
2008 CMP Champion - Archimedes Division
2007 Newton Division & Championship Winner
Unread 01-02-2007, 11:55
Here is a table of how to set the relay values to get the different results possible. It's from the IFI Spike document: http://www.ifirobotics.com/docs/spik...uide-sep05.pdf
We don't usually set both "rev" and "fwd" to 1 at the same time.
Both fwd=0;rev=0; as well as fwd=1;rev=1; should mean the motor is off.
This code will execute one section only as long as the switch is depressed and the other whenever the switch is not pressed.
G.T.S ..... (problem) Ami Schwartz Programming 3 28-01-2006 17:01
A linking problem T Shap Programming 6 15-01-2006 00:23
Problem Hailfire CD Forum Support 7 06-10-2002 15:02
PROBLEM!!!!!!?????? Clark Gilbert CD Forum Support 9 02-12-2001 12:43
