Go to Post Why drink Pepsi when you can drink Pepsi and program? - [more]
Unread 01-02-2007, 09:15
SoD SoD is offline
FRC #2230
SoD is an unknown quantity at this point
Microswitch problem
We have a problem with our micro switch. It doesn't work. We conncected it to the digital in/out, but it allways gets a '1' from the program no metter what, even when its disconnected. What is the problem?
Unread 01-02-2007, 09:21
Andrew Morris's Avatar
Andrew Morris Andrew Morris is offline
Oh hey, it's build season!
FRC #0177 (Bobcat Robotics)
Team Role: Student
Andrew Morris will become famous soon enough
Re: Microswitch problem
A few questions:
1. Do you have the digitalIO port you are using configured as an input?
2. What alias are you using to read the port(like rc_dig_in01)?
Basedd on your answers I should be able to tell you what is wrong.
Andrew
2010 Newton Division & Championship Winner w/ 67 & 294
2009 CMP Champion - Newton Division
2008 CMP Champion - Archimedes Division
2007 Newton Division & Championship Winner
Unread 01-02-2007, 09:35
SoD SoD is offline
FRC #2230
Originally Posted by Andrew Morris View Post
A few questions:
Andrew
1. Yes
2. Yes, we are using rc_dig_in01. This is the code we tried.
if (rc_dig_in01 == 1)
relay1_fwd = 0;
relay1_rev = 0;
Unread 01-02-2007, 09:42
The digital inputs are designed to return 1 if the switch is open or disconnected. It returns 0 only when closed.
The code you posted never does anything if the switch is closed (rc_dig_in01 is 0).
Try something like:
relay1_fwd = 0;
relay1_rev = 0;
else
relay1_fwd = 1;
relay1_rev = 0;
Unread 01-02-2007, 09:44
SoD SoD is offline
FRC #2230
oops I though it should give 1 xD
So if i change it to ==0 it should work?
Unread 01-02-2007, 09:53
Usually we give it something to do when it's equal to 1 and something different to do when it's equal to 0.
Relay1 will only change when we explicitly change it. The last thing we did will always be in effect.
For example, in your original code the relay was set to:
    relay1_fwd = 0; relay1_rev = 0;
in User_Initialization(), then your code changed to to the same value.
Nothing ever changed it to 1.
If you modify your code to use "==0" instead and change it to set the Relay to 1, then Relay1 will begin as 0 and change to 1 when you flip your switch, but nothing will ever change it back to 0 if the switch is flipped off again.
Unread 01-02-2007, 09:59
SoD SoD is offline
FRC #2230
Ok i think i understand, tnx alot ;p
Unread 01-02-2007, 10:24
SoD SoD is offline
FRC #2230
$@#$@#$@#$@# it still doesn't work X_X
The rc_dig_in01 is allways 1 even when we press on the microswitch X_X what is wrong here?
Unread 01-02-2007, 10:31
If you are using the micro switch that came in the kit, then there are different ways of wiring it.
Choose the wrong way and it will never be 0.
Let me see if I can find a picture....
Unread 01-02-2007, 10:32
Team Role: Student
You may have the switch plugged in wrong(white where black sould be). Otherwise I would need to know how you are checking the value(LED or printf statement) and see the code you are using.
Andrew
Unread 01-02-2007, 10:40
SoD SoD is offline
FRC #2230
Printf. And there are 3 plugins in the microswitch right? We connected the yellow one to the upper one, nothing to the middle one, and the red one to the lowest one
Unread 01-02-2007, 10:45
Should be black and yellow, no red at all.
Use only the outer wires at the RC digital input side.
The red is power and used only by devices that need power to work. A switch doesn't need power. It simply connects the signal wire (yellow) to the ground (black) or not to close or open the circuit.
If you have a multimeter you can use it to test that the switch is wired correctly.
Unread 01-02-2007, 10:55
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Thanks! We've got it working!
Unread 01-02-2007, 11:28
SoD SoD is offline
FRC #2230
Darn we now have a new problem
if (rc_dig_in01 == 0)
relay1_fwd = 0;
relay1_rev = 0;
else
relay1_fwd = 1;
relay1_rev = 1 ;
This is the code we are trying to use atm, but we have a problem. When the motor works foward, and i press the microswitch, it changes from 1 to 0 and the motor stops working. But when the motor is working backwards, and I press the microswitch, the microswitch turns to 0 but the relay1_rev remains 1 ;s
Whats wrong?
Unread 01-02-2007, 11:34
Team Role: Student
What motor? You haven't mentioned a motor before.
Andrew
G.T.S ..... (problem) Ami Schwartz Programming 3 28-01-2006 17:01
A linking problem T Shap Programming 6 15-01-2006 00:23
Problem Hailfire CD Forum Support 7 06-10-2002 15:02
PROBLEM!!!!!!?????? Clark Gilbert CD Forum Support 9 02-12-2001 12:43
