Go to Post The extra button could also just be a spare, but that's far less interesting than other possibilities, so let's keep speculating. - Caleb Sykes [more]
Unread 01-02-2007, 10:52
bruss6's Avatar
bruss6 bruss6 is offline
FRC #0843 (Wildcats)
bruss6 is an unknown quantity at this point
Pneumatic cylinder size
Yes, we were just wondering what the max diameter size is on the pneumatic cylinders. We want to know if we are allowed to use a 3" diameter, or if that is too large.
Unread 01-02-2007, 11:03
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: Pneumatic cylinder size
By the new FIRST update, you are only allowed to use pneumatic cylinders with a largest bore of 2". That still has a force of about 180 pounds.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 04-02-2007, 13:14
DonRotolo's Avatar
Back to humble
FRC #0832
The only cylinders you can use are those listed on the cylinder order form. No 3" cylinder listed = you cannot use one.
Don
Unread 04-02-2007, 21:50
bruss6's Avatar
I have looked for the documentation on the pneumatic rules but cannot seem to find anything restricting the use of a 3" cylinder. Can some one post a link to where I can find this information.
Unread 04-02-2007, 22:14
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
can't give documentation but I do know that you are only allowed pnematics that have been ordered from a FIRST supplier. (Bimba, Parker, etc.) and none of them will give you a 3" bore. why would you need it anyways?? It seems pretty overkill to me. Why not use two 2" bores?
Unread 04-02-2007, 22:24
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
You can only order cylinders in sizes listed on the form that is the last page of the pneumatic manual:
http://www2.usfirst.org/2007comp/oth...s%20Manual.pdf
Avaliable bores are 3/4", 1.5" and 2".
Ricky Quinones
Director of Sales - VEX Robotics
Unread 04-02-2007, 22:37
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Bolding added for emphasis.
Originally Posted by <R105>, Section 8, The Robot
<R105> There is no limit to the number of solenoid valves, air cylinders, pressure regulators, and connecting fittings that may be used on the ROBOT. They must, however, be “off the shelf” pneumatic devices rated by their manufacturers for pressure of at least 125psi. Besides the “free” pneumatic components listed on the Pneumatic Components Order form, additional air cylinders or rotary actuators may be purchased. However, they must be identical to those listed on the Pneumatic Components Order form (i.e. same part numbers), and obtained from a Bimba or Parker Hannifan distributor.
From the Pneumatics Components Order form (last page of the pneumatics manual), we see that only the following size & bore combinations are legal.
3/4" Bore: 0.5", 1", 1.5", 2", 2.5", 3", 4", 5", 6", 8", 10" strokes
1.5" Bore: 0.5", 1", 1.5", 2", 2.5", 3", 4", 5", 6", 7", 8", 9", 10", 11" strokes
2" Bore: 0.5", 1", 1.5", 2", 2.5", 3", 4", 5", 6", 7", 8", 9", 10", 12", 24" strokes
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 05-02-2007, 09:01
bruss6's Avatar
alright thanks for the posts. Looks like were gunna have to get a new cylinder.
Unread 16-02-2007, 16:37
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Be warned to keep an eye on cylinders your people are using. I didn't realize until after it was ordered that a subgroup bought a couple of 2" bore by THIRTEEN inch stroke cylinders.
Bimba makes them to order at the time you request them (they don't STOCK them). Therefore, not only can't we use them, they are UNRETURNABLE!
That error cost us several hundred dollars! (I guess we'll be using them for pneumatics training now...)
BTW... That's another thing to note - even if you specify "overnight shipping" on the cylinder order form, be aware that it does NOT mean you'll get them the next day! Their manufacturing is a first-come-first-served queue. Depending on their backlog, it can take them up to several days to MAKE the cylinders for you. (So, plan ahead!!)
However, you can check the "order status" online, and it'll show you when they'll make and ship your cylinders. You use your team number as the PO number, and the Ship-To's zip code to pull up the detail sheet on your order.
Note though that making Oernight can still a good idea. Although it may take them a day oor two to make your cylinder order, NOT specifying overnight means they'll go by Ground, which can take quite a while to arrive!
- Keith McClary
Chief Engineer, Tean 1502 "Technical Difficulties"
"I've had to advise on Pneumatics so long it's becoming my religion... I'm now the 'Ecpneumatical Counsel'..."
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
pic: rookie team 1481's 6 cylinder pneumatic system. (very organized isn't it...) CD47-Bot Robot Showcase 3 02-02-2004 23:19
pneumatic cylinder part numbers Ed Crammond Pneumatics 0 14-02-2003 19:27
Pneumatic Cylinder i-Factory Model Posted Ed Sparks Inventor 0 12-01-2003 23:27
Pneumatic Cylinder Length billy Technical Discussion 2 10-01-2003 08:30
2" Pneumatic Cylinder Posted Ed Sparks General Forum 0 27-01-2002 15:47
