Go to Post I always viewed Gracious Professionalism as "I may not agree with you or even like you but we need to work together to solve this problem. So let's get to work!" - Koko Ed [more]
Unread 01-02-2007, 09:26
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
pic: FEA - Stress Analysis of Frame Rail
Unread 01-02-2007, 09:29
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: pic: FEA - Stress Analysis of Frame Rail
My son was trying to use Inventor's FEA to figure out maximum stress on a section of ramp, but could not figure out how to set up the loading to represent pinned connections at the ends, they always came out fixed, as in your picture.
so he figured out how to roughly calculate the moment of inertia of the section, and calculated stress due to bending using the good old formula, with pencil and paper. Then we tested it by building a section and supporting it freely at the ends and standing on it.
Unread 01-02-2007, 11:48
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
I'm a little confused by the unit representation in the upeer left corner. It looks like I have to multiply it by 10^6 to get the load in psi and 1,576,000 psi seems a bit high for a load on a FIRST bot.
Also I've never done FEA on a bot part. If I'm concerned about a part I break out my copy of "Roark's Formulas" and do a hand calc.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 01-02-2007, 11:54
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
It looks like it says max: 1.105x10^3, which is more reasonable. That's really cool, though. I'm thinking we should try it with our ramp platform.
Regarding pinning, I vaguely remember some trick where you can model a (symmetrical) beam pinned at both ends by using a cantilevered half-beam with one end fixed and one end free, then applying the pin reaction force to the free end. Anyone else know this for sure?
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Unread 01-02-2007, 12:20
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
Very nice, and its a great experiment ... on the surface ...
However looking at the deflected plot shape I am a bit concerned about how you have your model constrained. When using FEA, in order to have meaningful results, it is critical to know a lot of background about structural analysis and to understand how your applied loads and boundary conditions can influence your outcome. Here at R-R we have several entire departments dedicated solely to their own areas of FEA due to the intricacies involved with properly utilizing these tools and the criticality and safety concerns inherent in our product.
It is amazing and encouraging for me to see FEA software available to HS students. It makes me wonder how talented our new engineering graduates will be over the next 5-10 years.
As a mechanical design engineer I use these tools for preliminary analysis to help compare different concepts. Our final designs are always put through extensive analysis by our specialists.
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 01-02-2007, 16:29
kramarczyk's Avatar
I agree that boundary conditions are everything in FEA. That's why we didn't use the absolute numbers for our decision, we looked at relative differences instead. This shot is one of a series that we conducted trying to determine an appropriate web width. We started with a tube without any weight reduction and noted the stress and deflection then proceeded to take out weight. We got lucky with the geometry and didn't have any significant singularities pop up and the models convereged pretty quickly for us.
We plotted max stress vs. weight and max deflection vs. weight and looked for the knee in the graph. We had a safety factor of 10 throught the analysis, but I'm not sure if the software was basing it on ultimate or yield strengths though, so I can't draw much of a conslusion from it. Some design choices should keep the rail from taking a point load hit (i.e. bumpers) so I am pretty confident that we'll have dropped about 40% of the frame weight with no loss in performance.
DIN Rail? cdennisxlx2 Inventor 1 19-01-2007 07:51
Stress StephLee General Forum 48 24-01-2006 00:25
pic: Stress testing 80-20! Andrew Blair Extra Discussion 2 09-05-2005 16:11
Driver Stress? dddriveman General Forum 55 16-03-2005 23:44
FEA Modeling Neal Turett Inventor 5 16-02-2004 20:33
