Go to Post Even at Mc Donalds, dinner with Dean would be really cool! - Josh Hambright [more]
Unread 01-02-2007, 11:55
Re: Microswitch problem
Here is a table of how to set the relay values to get the different results possible. It's from the IFI Spike document: http://www.ifirobotics.com/docs/spik...uide-sep05.pdf
We don't usually set both "rev" and "fwd" to 1 at the same time.
Both fwd=0;rev=0; as well as fwd=1;rev=1; should mean the motor is off.
This code will execute one section only as long as the switch is depressed and the other whenever the switch is not pressed.
G.T.S ..... (problem) Ami Schwartz Programming 3 28-01-2006 17:01
A linking problem T Shap Programming 6 15-01-2006 00:23
Problem Hailfire CD Forum Support 7 06-10-2002 15:02
PROBLEM!!!!!!?????? Clark Gilbert CD Forum Support 9 02-12-2001 12:43
