Go to Post Now I'm having visions of thousands of balloons and a grumpy old man. Oh, and a talking dog. No talking dogs on the field. Grumpy old men are ok - sometimes. - JaneYoung [more]
Unread 25-01-2007, 13:46
Setsanto's Avatar
Setsanto Setsanto is offline
FRC #1334 (OTHS RobOTics)
Team Role: Animator
Setsanto is a jewel in the roughSetsanto is a jewel in the roughSetsanto is a jewel in the rough
Send a message via MSN to Setsanto
Creating a skeleton
Is it at all possible to create a "skeleton" or summing like that in 3ds. More specifically, can u tell the program that those two cylinders are in fact an arm?
~Nick/1334
2008 : GTA Regional 7th Seed, Quarters
2008 : Waterloo Regional 4th Seed, Quarters
2007 : GTA Regional 2nd Seed, Quarters
2007 : Waterloo Regional Quarters
Unread 25-01-2007, 15:08
3dfernando's Avatar
3dfernando 3dfernando is offline
Pixel Transformer
AKA: Old Skull
FRC #2026 (Senai-RS)
Team Role: Animator
3dfernando will become famous soon enough3dfernando will become famous soon enough
Re: Creating a skeleton
I think you are talking about what we call "Rigging".
Rigging is the set-up of the "bones" of your character, something essential to animate it. Yes, you can tell to 3dsmax that an arm moves with two, or three articulations, etc.
Try looking the 3dsmax tutorials about "Rigging", "bones" and "Inverse Kinematics", etc.
Good luck! =)
Unread 25-01-2007, 16:39
Drew's Avatar
Drew Drew is offline
Drew
FRC #0302 (Dragons)
Team Role: Animator
Drew is a jewel in the roughDrew is a jewel in the roughDrew is a jewel in the roughDrew is a jewel in the rough
Send a message via AIM to Drew
just for help, you may want to check 3dtotal.com under free stuff, free models, skeletons. There is a free skeleton there.
http://3dtotal.com/
Unread 25-01-2007, 23:11
Testament-Doom's Avatar
Testament-Doom Testament-Doom is offline
The wanderer of all worlds.........
AKA: David Perrot
None #0555 (Team 555)
Testament-Doom is a jewel in the roughTestament-Doom is a jewel in the roughTestament-Doom is a jewel in the rough
Send a message via AIM to Testament-Doom Send a message via MSN to Testament-Doom Send a message via Yahoo to Testament-Doom
Basically, you can set ANYTHING as a sort of skeleton used as a rig
Teapot as the torso of the body? Sure! go ahead! XD
Testament-Doom's 3D art (If you want to check it out) - http://testament-doom.deviantart.com
"It does not matter how easy or hard it was to create your art, but the end result that matters most." - Me.
Unread 01-02-2007, 12:07
theanimator17 theanimator17 is offline
FRC #1312
theanimator17 is an unknown quantity at this point
How hard would it be to make a simple skeleton? like, human skeleton, the bones, and skull?
Unread 01-02-2007, 12:12
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
do you mean create a skeleton to use as a model or a skeleton to use as bone objects?
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
Unread 02-02-2007, 15:33
FRC #1312
Yup, to use as a model.
Unread 02-02-2007, 17:34
xrabohrok's Avatar
xrabohrok xrabohrok is offline
hunter of errors
FRC #1208 (The Metool Brigade)
xrabohrok is an unknown quantity at this point
I allways knew that one could use objects and bones to make a skeleton, I just never understood how to link it with the model in question.
"It's programming's fault" may be a viable excuse for just about everything, except the robot falling apart.
It will 'cause it can!
constants aren't. variables won't.
Unread 02-02-2007, 17:36
3dfernando's Avatar
Pixel Transformer
AKA: Old Skull
Team Role: Animator
"Yup, to use as a model."
Then you've got a lot of work with modelling =p
But it depends on how complex you want it to be... And the complexity depends on how near the camera will be from the skeleton... So, if you want to model a skeleton, i recommend to use poly modelling techniques, and also a good reference image, i found this one:
http://www.killgrove.org/ANT210/skeleton_withparts.gif
Good luck =p
Unread 03-02-2007, 13:43
FRC #1312
Oh, alright. So, start with cylinders for the bones, and then convert, and edit with the vertices's to get the same design as the bone? I'll see what i can do i guess. If not, i guess i can always find a free model somewhere maybe.
Unread 03-02-2007, 14:20
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
For the skull I would start with a plane and then make it into the skape of the skull. Then apply the shell modifier to add thickness to the skull.
A.K.A Llama
Unread 03-02-2007, 14:55
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
I wouldn't use cilinders. I would use boxes and just keep cutting and adding verticies to ma a skeleton.
I also do have a model of a skeleton somewhere on my computer.
A.K.A Llama
pic: skeleton bot pic 1 JoeXIII'007 Extra Discussion 1 17-07-2006 12:08
creating a joystick (oh joy) mechanicalbrain Electrical 15 24-05-2005 00:58
creating environments stinger 3D Animation and Competition 5 26-02-2005 22:19
Creating Videos Raven_Writer IT / Communications 13 20-06-2004 23:48
IPS Extruded Aluminum - great for robot skeleton! Anton Abaya Technical Discussion 2 10-01-2002 21:39
