Go to Post The first law of programming is that there are always ways of doing things quicker and in less space than you already are. - jgannon [more]
Unread 01-02-2007, 13:50
Keith Watson Keith Watson is offline
FRC #0957 (WATSON)
Keith Watson is just really niceKeith Watson is just really niceKeith Watson is just really niceKeith Watson is just really nice
PWM() vs Generate_Pwms() in Autonomous
A search of the forum and the readme's did not answer this for me.
The default Process_Data_From_Master_up() function now calls PWM() instead of Generate_Pwms(). The default User_Autonomous_Code() still uses Generate_Pwms(). Is there a reason autonomous does not use the hardware version?
Keith Watson - Professional Software Engineer
No relation to "Kevin" Watson, who created the camera tracking code.
Unread 01-02-2007, 14:27
Re: PWM() vs Generate_Pwms() in Autonomous
I believe it was only an oversight, since the point of the code is really the camera operation and autonomous isn't used.
Someone else encountered that issue
http://www.chiefdelphi.com/forums/sh...ad.php?t=52869
Unread 01-02-2007, 15:47
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
If I recall correctly PWM() is Kevin Watson's code, while Generate_Pwms() is IFI.
http://www.mikesorrenti.com/
Unread 01-02-2007, 16:11
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Yep, it certainly is .
-Kevin
Kevin Watson
http://kevin.org
Unread 01-02-2007, 19:59
FRC #0957 (WATSON)
Thanks for clearing that up Kevin.
pwm in autonomous mode AMIRAM Programming 5 30-01-2006 16:45
How to use Generate_Pwms() ? steven Robotics Education and Curriculum 0 01-04-2005 11:43
PWM problem in autonomous outofcontrol Programming 5 27-02-2004 11:58
Generate_Pwms? Kevin Karan Programming 5 08-02-2004 14:41
Generate_pwms() Broken? Larry Barello Programming 0 12-01-2004 18:52
