Go to Post Y'know... I think I'd much rather have big balls than hang myself... - FotoPlasma [more]
Unread 01-02-2007, 15:16
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
Re: Banebot 56mm gearbox - double D - RELOADED
By some twist of luck, my steel came early this morning AND I was able to get 20 minutes on the waterjet. So I now have four A2 tool steel 56mm carriers, which are about the same hardness as the originals but can be treated to pretty much anything from C20 to C40. I will probably shoot for C23 for now to match the current shaft.
My dimensions were as the drawings say, except:
a) I went tighter on the double-D: 0.470in (11.94mm) radius and 0.350in (8.89mm) flats. With the taper from the jet, this seems to be a good press fit, but may require some filing.
b) The pins will be press fit in the other direction, against the taper of the jet, so I just made their holes extra small, 0.150in (3.81mm), and I'll drill them out later.
The stock I used is McMaster part #9019K147, 18"x2"x5/32" A2 tool steel, but I wouldn't recommend it unless you have heat treating capabilities, since it comes soft (B89-99). I am just using it to have an adjustable hardness to play with.
In the attached picture, the two carriers at the left are the originals (1CIM, 12:1) with almost no visible damage after "mild" usage. The four at the right are the new A2 tool steel ones that I will try to harden to C23 for testing.
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Unread 01-02-2007, 15:34
cbpetrovic's Avatar
cbpetrovic cbpetrovic is offline
AKA: Mr. P
FRC #0166 (Chop Shop)
cbpetrovic is a jewel in the roughcbpetrovic is a jewel in the roughcbpetrovic is a jewel in the rough
Send a message via AIM to cbpetrovic
The stock I used is McMaster part #9019K147, 18"x2"x5/16" A2 tool steel.
The 4140 prehardened stock has arrived for us as well, and should be in the hands of our model shop along with the drawing package.
Our plan is to remanufacture the 3:1 DoubleD plates and we should have some test results this weekend. We're running a 4 transmission/motor chassis.
C. B. Petrovic - Team 166
Unread 01-02-2007, 20:55
ZZII 527's Avatar
AKA: Shane Colton
FRC #0097
Update:
I tried reassembling my 12:1 gearboxes today with the new press-fit A2 tool steel plates I cut and discovered a few issues with press fitting that I didn't think of:
1. I had to file out some to get it on at all, which is my fault because I went way under on the hole to be safe. Doing this, though, caused significant alignment problems. It was tough to get the press to go on straight and if it is even a little bit off, the gearbox will be tend to be stiff at certain positions.
2. Assembly was generally more difficult because of the extra constraint. I couldn't, for example, assemble the rest of it and slip the shaft in later.
3. Luckily this didn't happen because I over-filed a bit, but if you press it on real tight, it will be tough to get back off. I can't think of a good way to pull it back off since the plate comes so close to the bearing block.
So in conclusion, I think I'm going to file these out to be close fits, but not press fits. Loose enough that they will slip on and self-align during operation. If I cut more on the waterjet, I'll just make them 12mm x 9mm exactly.
Also, I was mistaken in my previous post: A2 tool steel will temper to C40-C65, not C20-C40. It comes already just below a C20. I will shoot for the low end of the tempering range, so as to avoid brittle failure.
Unread 01-02-2007, 22:50
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
one could use a bearing separator, maybe?
Unread 01-02-2007, 23:25
ZZII 527's Avatar
AKA: Shane Colton
FRC #0097
Probably would work. I'm sitting here watching American Chopper and filing carrier plates...it's mildly relaxing. The next set I put on I hope never to have to take off anyway. I think after I finish with this gearbox stuff, I'm taking the rest of build season off.
Unread 02-02-2007, 13:11
AKA: Dr. Brooks
no team (WRRF)
At this point, we have machined carrier plates and axles out of the 4130 steel that we have on hand, using a square broach for the carrier plate. We have hardened at 1600F with an oil quench, and tempered at 800F.
A link to a table showing the strength characteristics of 4130 as a function of the temperature for temper is shown below:
http://www.eng-tips.com/viewthread.c...=116052&page=4
Following is a listing for tempered 4130 steel:
UTS YS
C F MPa psi MPa psi El RA HB
205 400 1627 236 1462 212 10 41 467
315 600 1496 217 1379 200 11 43 435
425 800 1282 186 1193 173 13 49 380
540 1000 1034 150 910 132 17 57 315
650 1200 814 118 703 102 22 64 245
The yield strength at this temper is 173,000 psi and the elongation at break is 13%, not too brittle.
We have assembled and broken in the gear boxes using no load and 8 volt power, running both ways until the gear box "sped up" from the polish established on all the parts. This was about a half hour in each direction. We then inspected for any evidence of metal chips, and installed them in the robot.
We should get a day or two of testing by Monday. After some agressive testing, we will report the results.
The material is from McMaster and you can make these parts easily if you have access to a lathe, a mill, and a heat treating furnace. This approach to the problem is best described as Dr Joe's plan C. If you don't have this equipment, I would suggest that you head to a local machine shop that can heat treat with suitable material and the existing parts to copy with the modified square hole setup.
If I bought material just for this task, I would use 4340 steel and suitably adjusted hardening and tempering temperatures in order to get a little more strength while maintaining toughness.
Well, I would really use maraging steel from http://www.onlinemetals.com if I ordered material just for this, but I won't get into that.
Eugene
Unread 03-02-2007, 00:43
ZZII 527's Avatar
AKA: Shane Colton
FRC #0097
Update on the A2 tool steel carrier plates:
After cutting them on the waterjet, finishing the pin holes with a 5/32" drill bit, and filing the double-D to be a close fit, but not a press fit, I tempered the steel today. Here was my process:
1. Heat at 950C (1742F) for 20 min.
2. Air cool (A2 is air-hardening tool steel) until warm enough to touch.
3. Temper immediately at 650C (1202F) for 2 hours. Air cool. Repeat temper for two hours.
The high tempering temperature brought the hardness down to a C40 on one plate and a C39 on the other. (Tensile strength around 182 ksi.) I am hoping that this won't be too brittle.
A2 holds tolerance well in heat treatment, so the press fit pin holes worked fine. The double-D was a bit tight, but after a bit of sanding they seemed to go on easy. One gearbox assembly went smoothly. Putting the two stages in first and then fitting in the shaft later is much easier than messing around with a press fit shaft and carrier. It ran smoothly with the motor, drawing about 2.5A. (Is this normal? Good? Bad?)
The second gearbox is still having alignment issues, binding slightly in particular positions. I think the carrier plate may need some more filing to get it on straight. Maybe a fresh look at it tomorrow morning will do the trick.
So it is indeed possible to make a working HRC40 carrier plate out of A2 tool steel. It's a nice steel, because it can cool slowly, not deforming much, and still harden. McMaster also carries 5/32" (4mm) stock, saving one machining step. But it is somewhat expensive and needs to be heat-treated to get to the right hardness, so it probably isn't the ultimate solution.
The most important thing I learned so far is that a press fit makes assembly (disassembly) and alignment VERY difficult, and so I wouldn't recommend it. If I cut more, I'll cut them exactly 9mmx12mm. If the plate can self-align in the motor, it will run much more smoothly. But your results may vary, of course.
For now, I think I'm done. As long as the second gearbox goes together okay and nothing breaks this weekend when we drive the heck out of it, I think I'll be happy. We are using 12:1, 1 CIM per side, so I don't think I need to make a sqare-hole version in anticipation of needing the harder shafts. But I might cut some just in case..
Unread 03-02-2007, 01:39
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We draw about 5 amps with two motors, so yeah, I'd say you're good there.
Unread 03-02-2007, 20:13
AKA: Dr. Brooks
no team (WRRF)
We got a chance to test our 56 mm banebots transmission solution
today, using 12:1 gearing and two cim motors on each transmission.
As noted in the post earlier in this thread, we made new plates and
axle shafts out of 4130 steel, using a square hole, and hardened in
an oil quench at 1600F followed by a temper at 800F. The 4130 is
what we have on hand for heat treated welded parts, we would have
used 4340 for this application (or maraging steel considering the risk
to the function of the robot) if we had bought the material specifically
for it.
Our test was a half hour of ramming the robot into a old tire positioned
against a wall at full power from a distance of a foot or two, back and
forth. The test was stopped when everyone got bored of it. The
transmissions are doing fine with no apparent extra lash, but we have
not yet pulled them apart for inspection. We will do that when time
permits, there isn't all that much time available in the last two weeks
of the build period as we have our share of other problems to solve.
Have fun,
Eugene
Unread 03-02-2007, 21:57
for it.
Have fun,
Eugene
What wheel size, tread material, and floor/ground?
Unread 03-02-2007, 22:40
AKA: Dr. Brooks
no team (WRRF)
Wedgetop conveyor belting. Wheel diameter was about
5 1/2 inches. The robot was operated on carpet for the test.
Chain drive from the gear box to the wheels was 1:1.
Eugene
Unread 04-02-2007, 11:26
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Our team is also using these 56mm gearboxes. Now I have been reading through the forums and I am scared now! I am afraid these gearboxes will fail. We have signs of the gearbox binding or jamming. What is the best and simplest way to prevent this?
I am afraid that it may break like the images people have posted. What can I do to prevent this? From what I soaked up from previous posts is add lubricant, support the CIM, and break them in.
Also I found gear dust, very small amounts of metal inside the gearbox. What should I do?
Now I heard harding this plate may prevent the problem of the double D breaking. The problem is we don't know how to harden the plates, and I doubt we have the time. Also if these gearboxes fail, we don't have the money to replace them. So what should we do?
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 04-02-2007, 12:18
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by Arkorobotics View Post
I am scared now!
Don't be scared. Those with experience in these kinds of issues are working on a solution. They realize they have two weeks.
Small amounts of metal dust are not unusual, nor cause for panic. If you want, clean out the internals of the gearbox and re-lubricate.
The plates themselves are of a material that cannot be hardened, so again, folks are working on this and hope to have a solution. NOT having a solution might be a serious problem, they understand, so just the existence of this thread should be very reassuring.
For those really in a panic , go to a local machine shop and get a quote on making a shaft, 3:1 plate and 4:1 plate all with the square holes, from material that will be hardened to Rockwell C 23 - one set for each transmission you have. Install those and, the current thinking is, you should be good (or at least a LOT better) to go. If the price is reasonable, have spares made for Just In Case.
Don
Unread 04-02-2007, 12:22
ZZII 527's Avatar
AKA: Shane Colton
FRC #0097
All of the things you mentioned (lubricant, breaking in, supporting the CIM) are helpful. I'm guessing you are using just one CIM in each gearbox. The data and evidence so far suggests that if you treat this setup right, it will quite possibly survive without modification. Joe Johnson and BaneBots are working on a solution for making harder carrier plates that doesn't involve the teams doing heat treating themselves.
I can tell you from my own experiences (we are also running 12:1, 1 CIM per gearbox) that if you notice binding and the gearbox gets hot while breaking it in for a half hour, you may want to take it apart an look for tight spots. This will give you a chance to look at the carrier plate too for any signs of wear and add lubricant. There are instructions available from the BaneBots website for how to relieve common problems, such as the motor pinion sticking out too far.
Another fix that seemed to help yesterday was sanding (with fine grit) and/or polishing the round lip on the bearing blocks that fits into the ring gear housing and the flat surface opposite the carrier plate on the bearing block. This seemed to help with alignment issues, and the motor current went down by half an amp or more.
Unread 04-02-2007, 12:28
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
About the pinion, sorry, I haven't taken apart the transmission, but what is it? Where is it? Are there any pdf's or files that talk about taking the transmission apart?
Callsign: N6ARA
Banebot 56mm gearbox - double D related Joe Johnson Motors 78 31-01-2007 23:55
small banebot motor with 64:1 gearbox burkey_turkey Motors 16 29-01-2007 01:48
Banebot Gearbox chris31 Technical Discussion 45 15-01-2007 17:56
Attempting to Cut BaneBot 56mm Shaft edthegeek Motors 6 15-01-2007 08:51
56mm BaneBot Gearbox 15tooth sprockets. Where to buy more? VEN Technical Discussion 4 11-01-2007 14:45
