Go to Post Remember, if FIRST is your top priority, you need to look at your priorities. - Billfred [more]
Unread 01-02-2007, 15:41
Metalgod4eva Metalgod4eva is offline
None #0870
Metalgod4eva is an unknown quantity at this point
Function for O over a serial.
I am a happy computer programmer and well never played around with a robot before. Being a computer programmer I am use to the computer standard ways of doing things. I wrote this for the robot
 #include <stdio.h>
#define AMOUNT_OF_LINES 1
int reprint(void)
int i,x,r;
int farray[200],*fa;
FILE *fp;
fp = fopen("c:\\text3.txt", "r");
fa = &farray[0];
for(x=0;x<123;x++)
    *(fa+x) = (fgetc( fp ));
     printf("%s",fa+x);
fclose(fp);
int write(void)
 	  int c,x,i,y,n, *sp, string[200];
      sp = &string[0];
 	  FILE *fp;
 	  fp=fopen("c:\\text3.txt", "w");
    for(x=0;x<3;x++){
      scanf("%s",sp+x); }
      for(n=0;n<3;n++) {
      fprintf(fp,"%s",sp+n); }
      fclose(fp);
int main() {
   int x;
   write();
    reprint();
    scanf("%d",x);
    /* by metalgod4eva team 870 */
/*for loops not complete, still need to make another function */
Well as you can read its a nice file IO, I am looking to use the serial to O back to the computers hard drive and save and in looking in the source for the serial I found no O function back over its device. Maybe I just over looked it and its there or I will have to write it. If anyone has an idea or solution let me know. Also I think I might have to use fwrite instead of fprintf but no issues there. Dont complain if you do run it and find the garbage data I have not finished the fuction for the for loops yet. Thanks for your time and have a nice day!
Unread 01-02-2007, 18:35
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: Function for O over a serial.
The code for the robot isnt exactly like standard C for a computer, you might want to look at the default code
www.kevin.org/frc
And read the programming ref guide from IFI
http://www.ifirobotics.com/docs/lega...2-apr-2004.pdf
Unread 01-02-2007, 20:54
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
If I understand this is what you want. Just Printf all you info like you normally would. But write a custom app that reads those values and logs them to a text file. Is that what you want?
Unread 01-02-2007, 21:31
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Even simpler, forget a custom App, depending on the kind of data you're using a properly formatted printf(), Hyperterm and Excel are your best friend.
I had to monitor the PID response for last years robot and a bunch of numbers wasn't doing it for me, so I had a printf like this:
printf("%d,%d,%d,%d,%d",kp, ki, kd, error, output); // This is a loose guess at what it was
Then I told HyperTerm to save to a file, and let the robot run, then using Notepad++ (it handles large text files better than notepad does) I trimmed out the section I needed and imported to Excel as a CSV (Comma Separated Values) file. Then I re-saved to .xls and started graphing, thanks to Mark McLeod for that awesome tip.
Matt Krass
Dampening function for driving. Brad Voracek Programming 2 13-01-2007 14:18
Loop time for OperatorControl function? Debug blows... Chris_Elston Programming 10 13-02-2006 14:42
USB serial adapter for OSX? Validius Programming 1 05-01-2006 01:43
FIRST Over For WRONG 1430 russell General Forum 13 26-11-2005 16:01
USB to Serial converter for controller Ryan Collings Programming 10 22-01-2005 13:14
