Go to Post The less we talk about the game hints the faster they will come. - BrendanB [more]
Unread 01-02-2007, 16:45
CraigHickman
Posts: n/a
Re: pic: FRC488 Lift Mechanism Deployed
114 looks forward to working with you guys at both PNW and SVR! Looks very good! How long does it take to lift up a 120 pound robot to full height? Also, are there any dimensions on the total size of this platform? I'm very curious as to how easy it will be to drive onto this platform.
Unread 01-02-2007, 16:56
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Originally Posted by s_forbes View Post
Great looking cad model! Out of curiosity, is the material that the platform is made out of going to be transparent? I can imagine that it would be difficult to see what was going on on the field with those things folded up.
The material we're currently planning on using is semi-transparent. You can see shadows through it, but no fine detail. When folded, these lifts form something near a triangle atop our robot, so the profile along the long axis is pretty small. Looking at the side of the robot, though, is a lot like staring at a wall.
The gas springs haven't been attached yet, but under no load, they extend their full length in about two seconds. It ought not take much longer than that to lift a robot since the gas springs operate at a pretty constant force.
The overall dimensions of the flat part of the platform are about 37 x 45". When collapsed, the top is 2.25" from the floor. There will be ramps leading up to the flat portion that ought to be about 9" long.
--Madison--
...down at the Ozdust!
Unread 01-02-2007, 17:11
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Madison,
The lift looks really nice. We have been mocking up a couple of different similar designs using gas shocks and I have a couple of questions. First, in your design what keeps the two tall pieces of channel from just bending over? Second, (this is more of a rules interpretation question) are you placing any material between the bottom two pieces of metal (channel? Box tube?) and the carpet? I ask only because we are wondering if we need to so ast to not violate <R34> (the no metal touching carpet rule). I guess it depends on what is meant by a "traction device".
<R34> ROBOT wheels, tracks, and other parts intended to provide traction on the playing field may
be purchased or fabricated (“traction devices” include all parts of the ROBOT that are
designed to transmit any propulsive and/or braking forces between the ROBOT and the
playing field). In no case will traction devices that damage the carpet or other playing
surfaces be permitted. Traction devices can not have surface features such as metal,
sandpaper, hard plastic studs, cleats, or other attachments. Anchors (i.e. devices that are
deployed/used to keep one’s ROBOT in one place
and prevent if from being moved by
another ROBOT) can not use metal in contact with the carpet or other playing surfaces to
“stay put.” Gaining traction by using adhesives or Velcro-like fastener material is not
allowed.
Unread 01-02-2007, 18:07
Madison's Avatar
FRC #0488 (Xbot)
Originally Posted by DeepWater View Post
Madison,
The force of the gas springs at the start of the lift is exerted entirely vertically. As the lift extends, some force is exerted horizontally. It's about 25% of the total force, or 30 lbs. per gas spring. I should have done elaborate amounts of FEA on the linkages to determine their behavior given that they're seeing unprecedented loads for FIRST robots, but I honestly didn't have the time. Instead, we're taking a wait and see approach.
The linkages themselves buckled under the load in our first iteration. This was redesigned to accomodate that experience -- if something similar happens to the vertical pieces, we'll just make it stronger.
I'm pretty confident that the bottom of the lift will not be considered a traction surface, but I've been trying to also plan for nearly all eventualities and we hope to have something available to us to coat the bottom should the inspectors require it.
--Madison--
Unread 01-02-2007, 18:51
Fred Sayre's Avatar
Fred Sayre Fred Sayre is offline
AKA: Fred Sayre
FRC #0488 (xbot)
Fred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant future
Send a message via AIM to Fred Sayre
Madison,
Not on 488, but on my old team 824 we used all metal ball casters and they allowed it despite the metal contact with the ground. So it seems that normal forces against the ground should be okay, at least by that inspection.
Unread 01-02-2007, 19:39
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
our design for lifting is fairly similar to that, but I must say your picture is better than ours lol very nice! Hope to see you guys at atlanta! *crosses fingers*
Unread 01-02-2007, 19:52
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Looks great, as well as the rest of the robot, but I have a few questions - not sure if I completely understood your system.
Are the gas shocks preloaded, and then released to lift (launch? ) another robot? If that's the case, how hard is it to load them? Lifting a 150 pound robot 14" up in two seconds sure requires a lot of force.
Also, does the entire system pivot around that huge C-bracket?
Anyway, your robot sure looks great. It seems like we are using the same material on our ramps (does it, by any chance, weigh 1,5 kg per square meter? Incredibly strong stuff! )
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 03-02-2007, 22:14
NMR's Avatar
NMR NMR is offline
Heart & Soul of All Operations 696
AKA: Jianu Jr. the Sr.
FRC #0696 (Circuit Breakers)
NMR will become famous soon enough
Send a message via AIM to NMR
http://www.tommygate.com/downloads.asp
Consider this document signed.
Attending:
FRC Los Angeles
FRC San Diego
EAST Arkansas
Unread 03-02-2007, 22:18
Ericgehrken's Avatar
Ericgehrken Ericgehrken is offline
AKA: 3 Teams in 3 Seasons
FRC #0190 (Gompei and the Herd)
Ericgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud of
Send a message via AIM to Ericgehrken Send a message via Yahoo to Ericgehrken
Great system, nice model.
Team 3125
GHAMAS FIRST Robotics
Team President and Founder
2010-
2010 Suffield Shakedown Winner Thanks 178 and 177
2010 WPI Regional Rookie All Star
2010 WPI Dean's List Finalist
Team 195 Member 2007-2009
2007 CT Regional Winner Thanks to 1124 and 558
2008 FIRST Presidents Circle Winner
2009 Suffield Shakedown Winner thanks to 126 and 1124
Unread 03-02-2007, 23:17
Madison's Avatar
FRC #0488 (Xbot)
The gas springs are compressed before the match by some method which has yet to be determined. It'll likely involve students sitting on it or something similar while we lock things down. When we lift, the lock holding the springs closed will be released and they will extend and raise the platform.
We're using 2 125 lbf. gas springs, so it take 250 lbf. to lower the platform. We are considering switching to 100 lbf. or 75 lbf. springs to make it easier to reset the system -- but that switch is predicated upon their ability to lift a robot. They exert pretty near constant force, so it doesn't take more than a few seconds for them to fully extend.
The lifts do rotate around the large 'C-bracket'. The platform is made from 16 mm Polygal (www.polygal.com) and weighs .55 lbs./sq. in. -- about 11 pounds for both sides.
Thanks There'll be some pictures of our progress on the lifts uploaded sometime very soon.
--Madison--
pic: 498's Aircraft Carrier Deployed Donut Extra Discussion 18 19-01-2007 15:03
Controlling a "fork lift" type mechanism. Brad Voracek Programming 4 18-01-2007 22:53
pic: FRC488 - Hopper Mechanism Madison Extra Discussion 16 01-02-2006 13:11
pic: FRC488 - Overview Madison Extra Discussion 12 31-01-2006 13:16
pic: 476 - wings deployed CD47-Bot Robot Showcase 8 02-04-2003 23:37
