Go to Post I love how these contests always seem to find their way to go back to Dave Lavery and (pick one) Krispy Kreme/Heidi/Photoshop - DCA Fan [more]
Unread 01-02-2007, 16:43
Idaman323 Idaman323 is offline
In Theory, Our Robot Would Own.
FRC #1706
Team Role: Driver
Idaman323 is an unknown quantity at this point
Temperature
Do you guys know off hand a safe heating temperature for the electronics? including OI and FRC Controller?
TEAM 1706
2007 Judges Award, St. Louis (For our amazing ability to have bad luck)
2005 Rookie Inspiration Award, St. Louis
Unread 01-02-2007, 16:51
Re: Temperature
Are you asking about parts that were flooded? Remember that contacting IFI for ideas is the best bet. See my posts in the other thread for recommendations.
Unread 01-02-2007, 16:54
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: Temperature
You mean what heat they can safely work in? If so Ill have to check the PIC datasheet.
Unread 01-02-2007, 16:55
karlcswanson's Avatar
karlcswanson karlcswanson is offline
karlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nice
Re: Temperature
I think he means the heat safe for drying it.
Unread 01-02-2007, 17:01
Team 2021 Captain
AKA: Chris Davidson
Re: Temperature
I wouldnt try anything like putting them in an oven. Maybe just a warm dry room.
Unread 01-02-2007, 17:20
Nate Laverdure's Avatar
FRC #2363
Re: Temperature
From a related thread:
Originally Posted by Daniel_LaFleur View Post
100 degrees F in an oven for 3-5 hours should dry most components and not soften any of the plastics (do NOT go over 200 F).
Unread 01-02-2007, 17:54
FRC #1706
Team Role: Driver
Re: Temperature
I know. IFI is helping us out. But we might be able to get a vacuum oven to help why we wait
TEAM 1706
Unread 01-02-2007, 21:43
Re: Temperature
what is a vacuum oven?
We were suggesting a cooking oven set as low as possible with the door open. I know that my oven minimum setting is 125 degrees and we make beef jerky in the oven at that setting with the door open to the first detent. It gets warm but not hot. I have resurrected several wireless mics (dropped into toilets by unwitting guests) and a few cellphones including ridding the dreaded moisture inside the display.
However, in your case, don't do this without the approval of IFI. I perform this method on equipment that is essentially dead and I can't make it any worse. You have a thousand dollars wrapped up in the RC and modem. Let IFI make a choice on what to do.
Unread 01-02-2007, 21:56
Umm Errr...
Re: Temperature
Lower the pressure and water evaporates/boils more readily. Lower it enough and it will boil at room temp. We did a really cool experiment in one of my chem classes where we bioled water at slightly below room temp by putting it in a vacuum. This is often used in chem labs to dry samples without heating them.
1139 Alumni
Unread 01-02-2007, 22:24
Re: Temperature
That would work if you were sure that all the parts would survive a vacuum. I am thinking some will and some won't.
Unread 08-02-2007, 00:25
Jared Russell's Avatar
Taking a year (mostly) off
Re: Temperature
Eww. Who says engineering isn't a dirty job?
Unread 08-02-2007, 07:49
Re: Temperature
You obviously have never heard the joke that ends with "what?!? and give up show business?"
Unread 08-02-2007, 10:36
yodameister yodameister is offline
The Mad Chemist
FRC #2791
yodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant future
Re: Temperature
Sounds like a job for Mike Rowe of Discovery channel's "Dirty Jobs"
Unread 08-02-2007, 11:00
65_Xero_Huskie's Avatar
65_Xero_Huskie 65_Xero_Huskie is offline
One T
AKA: Mat
65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute
Re: Temperature
I think thats a fair statement. My mom always told me that if i cook over 200 F that they controls would get burnt and they wouldnt taste right.
Min-Max to the Max!
pic: digital temperature sensor Graham Donaldson Extra Discussion 6 27-05-2006 14:05
Temperature sensitive controller? maybe 8.2 V related? ericand Programming 6 10-03-2006 12:53
