Go to Post Mmmm scrap used parts. Dismantle, find data sheets and have fun.:D - techhelpbb [more]
Unread 01-02-2007, 18:48
Windward's Avatar
Windward Windward is offline
FRC #1452
Windward is an unknown quantity at this point
CPU issues
Our current CPU has some weird issues to it. Sometimes, when we start it, the programming light flashes red. However, when we restart it, it will turn green like normal and one PWM will automatically go forward. Then, if we disconnect and reconnect the 7.2volt battery, we can finally have control of the robot through the OI.
Anyone have any ideas?
Unread 01-02-2007, 19:00
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: CPU issues
Reload the Mastercode V13 and see if that helps any.
Unread 01-02-2007, 19:32
Windward's Avatar
FRC #1452
Re: CPU issues
Okay, when we load in the 2007 code we get the blinking red light error (programming light) with the same systems. But when we use last years customized code, it doesn't blink red, but it does not respond.
Unread 01-02-2007, 22:49
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: CPU issues
If your programming light flashes, it means that something bad happened while executing your code. If it happens with the default code, reload the user and the master code (as suggested earlier). If you still get the red, flashing programming light, there is most likely a problem with your RC. Contact IFI.
CPU Load in FRC RC DonRotolo Programming 7 22-01-2007 21:12
corrupt CPU? Windward Programming 3 14-01-2006 15:33
One smart CPU Max Lobovsky Programming 5 27-04-2004 03:52
best cpu _GP_ Technical Discussion 28 24-04-2004 21:15
cpu ivanslost Programming 1 15-02-2003 23:23
