Go to Post You can learn just as much from building a small robot as you can from a large bot because all of the key concepts are the same. - Greg Needel [more]
Unread 01-02-2007, 18:58
Happy Birthday! simpsonboy77 simpsonboy77 is offline
AKA: Garrett Dicken
FRC #0041 (RoboWarriors)
simpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond repute
Autonomous selector
I was wondering if there is a way to read from the OI, before autonomous, a value. We are coding multiple autonomous functions and I need a way to select which one to run. We can't put it on the robot because we have no inputs left. We have 1 completely unused port on the OI if that helps.
Thanks,
Garrett
Team 41
Help with Selector Switch Slick Programming 2 16-02-2005 16:09
[OCCRA]: hose clamps on drill transmissions' gear selector? greencactus3 OCCRA Q&A 1 06-10-2004 05:28
Beacon selector switch? How to find/make? Fen Programming 13 12-02-2004 16:31
Team selector switches on ISAAC Lloyd Burns Robotics Education and Curriculum 0 17-12-2002 08:32
Channel Selector David Kelly Technical Discussion 6 03-06-2001 01:15
