Go to Post At GLR our team only had to deal with a bunch on kids seeing snow for the first time. With all the ensuing snow fights and vainly trying to run up the giant snowy hill behind the arena. - Kevin Sevcik [more]
Unread 02-01-2007, 07:45 PM
Robo_Coyote's Avatar
Robo_Coyote Robo_Coyote is offline
Cheap_Shot
AKA: Chris Chandler
FRC #1323 (MadTown Robotics )
Robo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to behold
pic: Screw 1
Unread 02-01-2007, 08:32 PM
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: pic: Screw 1
FIRST supplied a list of all the pneumatic parts. You should be able to find out who made it and then search their site to find a seller.
Unread 02-02-2007, 07:50 AM
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: pic: Screw 1
You should be able to get an equivalent part from your local Swagelock or Parker distributor. Just make sure you verify the NPT fitting sizes on the BOM.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 02-03-2007, 02:14 AM
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Re: pic: Screw 1
The rotary cylinder is a Bimba Pneu-Turn Model PT-017090 (or PT-017090–M if you ordered "magnetic").
This part number translates to:
-- PT = "Pneu-Turn" line (rotary cylinder)
-- 017 = 3/4" bore
-- 090 = 90 degree rotation
-- M (if added at the end) = Magnetic option
The thread on the ends of this cylinder is #10-32UNF. IMHO, what you really want is a #10-32UNF Push-On connector, so you can go straight to the tubing...
SMC makes them. See the "kq2.pdf" on either the FIRST website (or SMC's, at:
http://www.smcetech.com/CC_catalogs/...f/KQ2_Inch.pdf)
Check with your local SMC dealer to be sure, but if I read this doc correctly, I *think* the part number would be one of:
- Straight connection = KQH07-32 (or KQH07-32S with sealant pre-applied)
- 90deg Elbow style = KQL07-32 (or KQL07-32S with sealant pre-applied)
To find your local SMC dealer, go to: http://smcusa.com/ Enter your state in the "Support Center" box on the left menu, and you'll get the local SMC stocking distributor list. Call them, ask their FAE to verify that part number, and check stock for it. IF they have it, I'd recommend getting one with the sealant pre-applied. That thread is SMALL, and it's tough to use the teflon tape on it without risking getting some in the cylinder!
I hope this helps! (If so, feel free to add to my rep. Thanks!)
Please let me know how this works out! (And if they suggest a different SMC part number, please forward that back to me as well. Thanks!)
- Keith Mc.
Chief Engineer 1502 "Technical Difficulties"
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Screw drive motor top dog Motors 7 02-01-2005 09:43 AM
Archimedes Screw Greg Perkins General Forum 10 01-19-2005 11:19 AM
Terminal Screw Strips? Jay05 Electrical 2 03-09-2003 09:48 PM
Screw jack system Gui Cavalcanti Technical Discussion 6 01-19-2003 01:07 PM
Lead Screw Nut archiver 2000 1 06-23-2002 10:49 PM
